intermittent no spark
Old Jun 24, 2005 | 12:21 PM
Quackhead94ranger's Avatar
Quackhead94ranger
my 78 f150 (400m) isnt getting any spark. it will start then stop right away (wont stay running) and then i can crank it and it will just crank, but wont start. i pulled the first spark plug wire to test for spark and it started right up and ran, but eventually i got no spark after starting it a few times. obviously its ignition related but were do i start. its got a msd ignition system on it (dist., coil, module), so any help would be appreciated.
Old Jul 2, 2005 | 02:40 PM
LxMan1's Avatar
LxMan1
I would first check for voltage at the + side of the coil. It could be a bad ignition switch or a bad resistor wire to the coil.
