something is wrong
Old Nov 26, 2011 | 08:14 PM
  #31
Kelsy Vincent's Avatar
Kelsy Vincent
Originally Posted by Maxium4x4
Safety first but you get the idea.... have someone assist you to make sure the secondary fuel bowl is filling. After that I am exhausted for ideas to give you. Usually a no start condition the first known issue is the ICP sensor failed, you can disconnect it to let the program fault, but you are showing no codes at all for any possible combination.
i just coded it and the only code that just sowed up is the EGR... but i buypassed that so would that cause anything?
Old Nov 26, 2011 | 08:18 PM
  #32
Kelsy Vincent
He is tagging onto the thread, subscribing, common so one can follow a thread and offer advice when needed.
" thanks i am new and only 19 so i am not really use to this.. the truck was giving to me and it was blowing out white smoke and loosing antifreeze, now i had it to running better then ever and not it wont even start so i am not sure what is going on but i am gettin really frustrated with this truck."
  #33
Maxium4x4's Avatar
Maxium4x4
What was the code number?
Old Nov 26, 2011 | 08:21 PM
  #34
Kelsy Vincent
"po 400 it is"
Old Nov 26, 2011 | 08:22 PM
  #35
Maxium4x4's Avatar
Maxium4x4
If you replace or delete the EGR cooler, the oil cooler is replaced also. Did you replace the oil cooler?
Old Nov 26, 2011 | 08:26 PM
  #36
Kelsy Vincent
No the oil cooler is still there it is just the egr delete
Old Nov 26, 2011 | 08:31 PM
  #37
Maxium4x4's Avatar
Maxium4x4
OK, the P0400 will not disable the truck, check for fuel flow in the upper filter housing. Have you recently changed the fuel filters? What brand did you use if you did?
Old Nov 26, 2011 | 08:33 PM
  #38
Kelsy Vincent
last week and Fram
Old Nov 26, 2011 | 08:49 PM
  #39
Maxium4x4's Avatar
Maxium4x4
You may have pinched or cut the lower filter O-Ring on the HFCM, just took this long to finally give you a problem. Low or no fuel pressure is where I would start looking.
Old Nov 26, 2011 | 08:54 PM
  #40
Kelsy Vincent
" ok thank you i will up date you tomorrow i am going to give up tonight... thanks alot for helpping me..."
Old Nov 26, 2011 | 08:57 PM
  #41
Maxium4x4's Avatar
Maxium4x4
No problem Kelsy, we try and Help with the information supplied.
Old Nov 26, 2011 | 10:33 PM
  #42
bismic's Avatar
bismic
My compliments to you for your persistence John .....................
born2race59
Oct 3, 2011 08:38 PM
Bill2
May 3, 2011 11:37 AM
ChadSD
Feb 1, 2011 06:17 AM
A-TUCK
Aug 23, 2010 07:52 PM
Droolinforparts
Feb 8, 2008 06:26 PM
