I HAVE A 2005 F350 . WHICH HAS A BUSTED EGR COOLER
I WOULD LIKE TO KNOW WHAT ADVANTAGES THE EGR DELETE OR THE EGR BYPASS COULD DO FOR IT.
I WOULD ASSUME THE OIL COOLER NEEDS TO HAVE SOMETHING DONE TO IT AS WELL?
IF I GO THAT ROUTE IS THAT ALL I NEED TO DO?
THE TRUCK HAS 200K AND HAS NO MODS. I REALLY DON'T WANT ANY MODS. IT RUNS AND PULLS FINE. ALTHOUGH IT COULD USE A LITTLE BETTER FUEL MILEAGE.
Welcome to FTE. Scroll a little further down the main forum listing and you'll find the 03 - 07 6.0 diesel section. Ask the same question down there to the folks with your same motor and they can give you all the details you need about the EGR delete.
Some of them get cranky when you use all caps, so you might want to hit the caps lock button before you ask.
