something is wrong
Old Nov 26, 2011 | 07:35 PM
LOOnatic's Avatar
LOOnatic
Originally Posted by Kelsy Vincent
" yes the HFCM is running" "it is not even on the road so no miles, but everything kicks on the way it sould but it just does not want to start?"
Just trying to help you out and checking for codes is the 1st place i would start.
Old Nov 26, 2011 | 07:38 PM
Kelsy Vincent's Avatar
Kelsy Vincent
" i know.. i checked for codes and there was none at all... so then what do i do."
Old Nov 26, 2011 | 07:41 PM
Maxium4x4's Avatar
Maxium4x4
Going to arm chair it, make sure your secondary fuel filter bowl is filling with fuel and do you have an early or late 2004 build? The ICP (Injection Control Pressure) sensor will be located under the turbo on an early build, right hand (passenger side) front valve cover on late build.
Old Nov 26, 2011 | 07:44 PM
Maxium4x4's Avatar
Maxium4x4
Just for reference, what product did you use to read for codes?
Kelsy Vincent
" the early 2004 model"
Old Nov 26, 2011 | 07:46 PM
Kelsy Vincent
"OBT 2 is what i used"
Old Nov 26, 2011 | 07:49 PM
Maxium4x4's Avatar
Maxium4x4
OK early 2004 the ICP is located under the turbo, check the upper or secondary fuel filter bowl to see if you are getting fuel.
Old Nov 26, 2011 | 07:51 PM
Kelsy Vincent
" yes i am, as far as i can see "
Old Nov 26, 2011 | 07:58 PM
Maxium4x4's Avatar
Maxium4x4
When you pull the cap fuel will be there, have someone turn on the ignition to run the pump while you watch.
Old Nov 26, 2011 | 07:59 PM
Maxium4x4's Avatar
Maxium4x4
if you have fuel and no codes we have nothing to go on. Have a friendly Ford Tech near you?
Old Nov 26, 2011 | 08:01 PM
Kelsy Vincent
" if i do that is fuel going to shoot at my face... i know this is a dumb question but i dont fell like going to the hospital tonight i have to work in the AM....
Old Nov 26, 2011 | 08:05 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Suscribing.......
Old Nov 26, 2011 | 08:09 PM
  #28
Kelsy Vincent
Originally Posted by Shaneb75
Suscribing.......
" what is that suppose to mean?"
  #29
Maxium4x4's Avatar
Maxium4x4
Safety first but you get the idea.... have someone assist you to make sure the secondary fuel bowl is filling. After that I am exhausted for ideas to give you. Usually a no start condition the first known issue is the ICP sensor failed, you can disconnect it to let the program fault, but you are showing no codes at all for any possible combination.
Old Nov 26, 2011 | 08:11 PM
  #30
Maxium4x4's Avatar
Maxium4x4
He is tagging onto the thread, subscribing, common so one can follow a thread and offer advice when needed.
