something is wrong
Old Nov 25, 2011 | 08:16 PM
Kelsy Vincent's Avatar
Kelsy Vincent
Question something is wrong
i own an f350 6.0 dully diesel, and it is not starting, it seems like it is not getting fuel.. i already replaced the egr cooling box and had it up and running and now it wont start again! so if anyone can help me please...
Old Nov 25, 2011 | 08:19 PM
powerstroke72's Avatar
powerstroke72
Welcome to FTE.
I've moved your thread to the 6.0L Powerstroke Diesel forum where you'll receive better response to your question and assistance with your issue.
Old Nov 25, 2011 | 08:29 PM
blueline970's Avatar
blueline970
Welcome to FTE. Check out the tech page on the 6.0.
https://www.ford-trucks.com/forums/3...ch-folder.html
There is lots of good info in there and it doesnt help post up some more info on your truck. Year, mileage, ect............
Old Nov 25, 2011 | 09:11 PM
bismic's Avatar
bismic
Tell us more about the work you have done. Was it the EGR cooler that was replaced (don't know what an EGR cooling box is). Why was that work required?
In the Tech Folder link above, there is a No-Start thread that might help.
Old Nov 25, 2011 | 09:13 PM
BLADE35's Avatar
BLADE35
First off welcome to FTE
Did you change the oil cooler to
did you do the work
Old Nov 26, 2011 | 06:52 PM
Kelsy Vincent
um no and what does that have to do with the fuel pressure and yes i did
Old Nov 26, 2011 | 06:54 PM
2006powerstroke90's Avatar
2006powerstroke90
Ouch, Benny trying to help ya out that's all.
I doubt your problem is fuel related at all.
Good luck. Hope someone wants to help you out.
Old Nov 26, 2011 | 07:00 PM
Snuggyworm's Avatar
Snuggyworm
hello kelsy vincent, wat year is ur vehicle? also, take a look at our tech folders. u might be able to figure out ur problem a lot better, or at least better than before.
Old Nov 26, 2011 | 07:01 PM
EXbowtieguy's Avatar
EXbowtieguy
Um because you changed the EGR cooler for a reason which is usually a rupture which is usually caused by a clogged oil cooler.
Old Nov 26, 2011 | 07:07 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE Kelsy Vincent We have to ask questions to see what is going on since the truck is not here. You changed the EGR cooler and the truck does not run is what I take from your post. Anything else that was done between the time frame? How many miles after start up did this occur?
When you Key the truck On do you hear the HFCM (Horizontal Fuel Conditioning Module) run? Located on the drivers side frame rail under the truck. Give us all the information you can and we will help out. Link to a No Start Condition, Click Here
Old Nov 26, 2011 | 07:24 PM
Kelsy Vincent
" yeah i got it running for like a week with out any problems after i changed the box... i bypassed it by the way and now it wont run again... i am going to sell it but i still want to know what is going on with it.....
Old Nov 26, 2011 | 07:26 PM
Kelsy Vincent
" no that is not y i changed it...... but thanks for telling me that..
Old Nov 26, 2011 | 07:28 PM
Kelsy Vincent
" 2004, the 6.0 "
Old Nov 26, 2011 | 07:29 PM
Kelsy Vincent
"yup........"
Old Nov 26, 2011 | 07:32 PM
Kelsy Vincent
" yes the HFCM is running" "it is not even on the road so no miles, but everything kicks on the way it sould but it just does not want to start?"
