3 speed to overdrive conversion?
Josh
I thought about the gear vendors OD for my '79 460, but they do get pricey...
Gear Vendors Under/Overdrive Ford 2-Wheel Drive 3-Speed Automatic.
Figure $2500 for GV and fab work and gas is almost down to $3 here. 833 gallons!!! Figure 15 mpg equals 12,495 miles.
Just something to think about it.
Josh
The axle ratio in my 72 is 3.25 (has a new motor) and has no problems in overdrive, it might not race up a hill in overdrive but it can hold speed, I think it has a 28% overdrive. But getting back to the OP 15mpg isn't bad for a truck intown. Most of my driving to and from work is highway 22 miles one way a short distance to the highway and the same when I get to work, so I loved it, it made my 72 the best gas milage vehicle I owned (but it is also feul inj.).
But basically if you want overdrive you can swap in a overdrive trans in a 2wd easy, and do it a hell of a lot cheaper than $2000+. I probably wouldn't buy the gear vendors unit now in my life, but the op was asking for info without replacing his trans, not quite the cheapest alternative.
If so, the older OD units will not bolt to your trans. Those were BW transmissions. Those are getting hard to find.
As per prior posts, a GV unit new is $3k, and would require a divorced mounting, DS work etc.
An overdrive trans is the only practical way to do it.
4 speed OD from late '70s to mid '80s would approximate your 3 speed gearing with 4th being over. Floor shifter required. Possibly a direct bolt in.
Mazda or ZF from later models: floor shifter, hydraulic clutch, additional fiddling.
T5: adapter, floor shifter, additional fiddling.
You have an all-synchro 3 speed, right?
set up for a lever so that isn't going to work out so good? :)
The ZFs for bigger blocked engines are setup with and external slave so
they have a lever (from what I've read) so a mechanical system could be
rigged up I'd guess?
Alvin in AZ
ps- where's the OP? :/
I don't really know but the ZF's 351w/300i6 aluminum bell housing ain't
Alvin in AZ
Alvin in AZ
Oh I see could you take the 3 speed bellhousing put it on the ZF and just re drill the holes to mate the tranny to the bell housing?
bigsub
1999 to 2016 Super Duty
03-14-2007 07:47 PM
elsmith
07-15-2001 10:59 PM
