3speed overdrive
Old May 20, 2008 | 05:50 PM
Retiredfire's Avatar
Retiredfire
Red face 3speed overdrive
Can anyone tell me if Ford had a 3speed overdrive on the column . 1967 - 1972
Old May 21, 2008 | 05:38 PM
imalooker's Avatar
imalooker
Smile
I had 1971 Ford f100 that I bought new, and it had a 3 speed column shift with overdrive, hope this helped you.
Old May 23, 2008 | 01:47 PM
Freightrain's Avatar
Freightrain
Yup, they had them.
Old May 23, 2008 | 02:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Overdrive?
You betcha...1953/72 Ford F100's could be ordered with the Borg-Warner 3 Speed Overdrive.
The 1953/64's used the T-86 unit, the later trucks used the T-85N unit.
The cars also used the same transmissions from 1949 thru 1967.
Gas mileage: Around town, don't expect much of a change, but on the highway, it's a different story.
Over 20 MPG is obtainable, depending on driving conditions and your speed.
Would you believe 28.7 MPG in a 1965 F100 with a 390?
On flat terrain at 45 MPH, that's what I got on a rod run on old Route 66 from Seligman to Topock AZ back in the late 1980's.
My usual highway mileage is around 22.
Old May 24, 2008 | 01:07 AM
Cowboy34's Avatar
Cowboy34
i have a 70 Ford F100 with a 3-speed and how can i tell if it is or has over drive,the truck does not have a motor in it
