2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Electronic problems after battery change
Old Dec 16, 2011 | 01:37 PM
berry1234's Avatar
berry1234
Only Nav. .
Old Dec 16, 2011 | 07:04 PM
TCAS007's Avatar
TCAS007
Looks fine and works fine I just need help with the sound settings:
https://www.ford-trucks.com/forums/1...l#post11162950
ImageShack® - Online Photo and Video Hosting
Uploaded with ImageShack.us
Old Dec 16, 2011 | 07:10 PM
berry1234's Avatar
berry1234
Looks nice. Did have to get adapter to connect it to the stock amps?
Old Dec 17, 2011 | 06:48 AM
RI-Matt's Avatar
RI-Matt
Is the factory subwoofer working?? Was there any connection on the back of the new radio to connect the factory sub plug??
Matt
Old Dec 17, 2011 | 10:19 AM
TCAS007's Avatar
TCAS007
I got all of the adaptors and Ford Expedition kit but honestly I had it installed as it was not much.
Been busy to check everything so where is the amp and subwoofer? Did not think it comes with a woofer.
Old Dec 17, 2011 | 11:42 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Originally Posted by TCAS007
They need the part number that fits and all except one I saw matched with mine. They look all the same though, would build in but not work.
That is what I was told at Ford at both places
funny...because that is a bald faced lie
ANY radio from a 2004/2005 through 2008 Ford with the same style double din radio will plug into and work on ANY other Ford from those years. Even some 2003 models have those radios.
I sold my stock 08 Expy radio to a guy with a 2004 F-150. I even put it into his truck for him. Bolted right up with no modifications. He had a XLT with my Premium 6 disc/MP3 radio (3 harnesses on radio vice his 1 harness for truck)
Disclaimer:
Exluding NAV...they must be programmed to vehicle build
Base radios have 1 harness plug - the main power, speakers
Mid Level radios have 2 harness plugs - main power/speakers, steering wheel controls/Aux input
High End radios have 3 harness plugs - all the above and a Subwoofer output
If you Expy only has the 1 harness, a 3 harness radio will work fine. Make sure you don't use a Shaker 500 or 1,000 radio from the Mustang. They depend on the Door speakers for the bass. They don't sound right in non-shaker vehicles due to that.
Old Dec 17, 2011 | 11:45 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
looks good. I have the Kenwood DDX 616 installed in my Expy. You may not want the Sub connected if you have one.
Left interior panel behind the 3rd row seat is where you can find it. If the panel has a "grille" cut in there, you have a subwoofer.
I have my sub turned down to -6 on the radio...and it pushed harder than I like. I feel bad for the kids at times and have considered unplugging it. The Kenwood HU pushes alot more power than the factory radio does
Old Dec 17, 2011 | 07:44 PM
RI-Matt's Avatar
RI-Matt
I'm pretty sure all Eddie Bauers, Limiteds and King Ranch's came with the Audiophile setup which would include the subwoofer located in the driverside rear panel. The amp is mounted to the top of the sub enclosure. Just crank the bass up and put your ear to the sub grill, if it's not thumping then it's not hooked up.
What wiring harness/adapters did you get and where?
My guess is the shop that did the install didn't hook up the sub plug in the dash to the radio. Seen it happen numerous times.
Matt
Old Dec 17, 2011 | 11:49 PM
TCAS007's Avatar
TCAS007
Thanks for all of the answers.
The subwoofer is not working for sure. I think there is a sub but can't remove the grill to check. Also I am not sure if worked before but I think so as the bass was rather dominant.
I guess I'll drive back to the store and let them check it. They might have messed it up.
The radio settings do not show the subwoofer option activated.
Old Dec 19, 2011 | 10:30 AM
berry1234's Avatar
berry1234
http://www.amazon.com/05-08-FORD-RAD.../dp/B001EASQ74
This is needed for your aftermarket radio to use the factory sub. It interfaces the aftermarket radio with the can bus factory setup.
Old Dec 19, 2011 | 02:45 PM
TCAS007's Avatar
TCAS007
Looks like it as the dimmer does not work as well.
They got me an appointment for Thursday to check it...
Old Dec 23, 2011 | 03:08 PM
TCAS007's Avatar
TCAS007
They forgot to hook the sub on and did it with an additional wire. 30.- of labor but it works now.
Old Dec 10, 2013 | 09:56 PM
  #28
THeagle1's Avatar
THeagle1
Hey guys - 1st post but a long time reader. Same thing happened to me yesterday. Listening to radio with ignition off & it the radio turned off (time expired while I was waiting) so I turned the ignition on then back off & continued to listen to the radio. When I went to start the Exped, the battery was dead. I got a jump from a friend and it appears to be fine. Fired up 15 minutes later & haven't had any problems since, only the radio backlights, steering wheel controls, and AUX input.
2 Questions: what is the exact number/unit that I would need for a factory replacement [Audiophile, Rear DVD, Sub - but no Navigation System]? I've seen a couple out there that I think are the same, but want to double ck.
If I do go with an aftermarket head unit, exactly what would I need to maintain working order of all current stock options - Rear DVD, Sub, Steering Wheel Controls, Aux Input. The head unit won't be DVD or Navigation.
Thanks everyone - greatly appreciate your insight & experience.
Old Dec 11, 2013 | 06:48 PM
  #29
berry1234's Avatar
berry1234
Old Jul 13, 2017 | 09:28 AM
  #30
ATOTH's Avatar
ATOTH
04 navigator fuses
Get This....had all fuses checked when I jumped my 02 navigator and radio went out, because all these fuses mentioned for the radio were not blown. Funny thing, is that the #30 fuse(30 amp) was blown. Replaced it and "WALLA", it worked! Now there is no mention anywhere that fuse #30 has anything to do with the radio/navigation system. Just an FYI
C Braves Win
2004 - 2008 F150
Jan 20, 2014 08:28 PM
Jrakar
Nov 1, 2011 02:56 PM
79fordf250pickup
Feb 14, 2011 08:10 PM
stroken
19
Sep 26, 2008 08:29 PM
Rancheroracer
2004 - 2008 F150
Feb 12, 2008 11:02 PM
