went to go leave my house and click, no start, just doesnt turn over, pulled chip and tried no luck, took apart steering column, still no luck, moved the shifter all around and still no luck, any ideas! please help!!!
If you heard a click then I would say to check all of your battery connections including the grounds and the wires on the starter. Did by any chance you leave anything on that may have killed the battery?
siruis satelite radio, for like an hour, all the lights and everything work. just when i turn the key the vacumm pump shuits off and the odometer and radio go out, but all the other lights and all stay on.
The satellite radio won't drain the battery. I have left mine on for much longer than that.
If you have a volt meter check the batteries to make sure they have voltage. like I said above check the connections, a lose connection will exhibit the same symtoms that your describing. Kenny how old are tha batteries?
You have a dead spot on the starter. When you tapped it it "moved" from the dead spot.
After the connections I was going to suggest you try that next. Time for a new starter. You should get a DB. Do you have the link?
Talking to kenny on the phone right now as we speak, just wanted to let all of you know that he smacked the starter a few times with a LFH and it started... Looks like i gotta find that receipt now...
