IDM Check?
Old Nov 22, 2011 | 10:31 PM
MauleOne's Avatar
MauleOne
IDM Check?
How can I check my IDM on my E99 to see if that is what is causing my rough idle and occasional CEL along with engine only running on few cylinders and no power.
Old Nov 22, 2011 | 11:01 PM
BigAlsPSD's Avatar
BigAlsPSD
Run Buzz test that will fire all the injectors, and report any codes stored in the IDM, other than that you will need to check the wiring. Usually if the Buzz is firing for all injectors, your IDM will be ok.
GB_Tech_Bulletin_103_Ford IDM_Module_Replacement (1).pdf
Old Nov 22, 2011 | 11:51 PM
MauleOne's Avatar
MauleOne
IDM
Thanks, exactly what I needed!
Visseroth's Avatar
Visseroth
What he said and if you haven't done the 50 cent mod yet now would be a good time. Also check the wiring harness above the driver's side valve cover. It has a tenancy to rub on the valve cover.
Old Nov 22, 2011 | 11:59 PM
MauleOne's Avatar
MauleOne
IDM
Did 50 cent mod. Injectors check out ok. Will look for wiring damage. Have rough idle and occasional complete breakdown of engine with CEL and OD flashing . Very rough running on only a few cylinders. Then runs ok.
Old Nov 23, 2011 | 12:39 AM
Visseroth's Avatar
Visseroth
Change out the CPS as well just to be sure that isn't it.
Old Nov 23, 2011 | 12:57 AM
MauleOne's Avatar
MauleOne
IDM
Changed CPS, no change in performance
Old Nov 23, 2011 | 01:02 AM
Visseroth's Avatar
Visseroth
unplugged your ICP?
That's about all I can think of right now.
Old Nov 23, 2011 | 01:20 AM
MauleOne's Avatar
MauleOne
IDM
No change plugged or unplugged, also MAP
Old Nov 23, 2011 | 01:21 AM
Visseroth's Avatar
Visseroth
Have you tried wiggling the under valve cover wires going into the valve cover seals. Maybe you have a loose connection.
How did the injectors sound when you ran the injector buzz test?
Old Nov 23, 2011 | 08:56 AM
Steve_250's Avatar
Steve_250
Clean the IPR?
Warning...
Don't snap off the tip of the needle!!!!
Old Nov 23, 2011 | 09:24 AM
01PS's Avatar
01PS
What codes when the SES trips? Wiggle test on CPS, ICP, and IPR plugs?
Old Nov 23, 2011 | 11:32 AM
MauleOne's Avatar
MauleOne
IDM
Inectors sounded ok. Did get a contribution code for #1 and changed it. Still have same code.
I am away from home for three weeks and don't have data with me.
As I remember it was a P02xx code.
It seems that either the IDM or the wiring has a fault.
katula
Oct 8, 2010 01:31 PM
johnsonswamp
Oct 23, 2008 06:32 PM
tneyman
Mar 24, 2007 01:42 PM
paulgc
Oct 10, 2006 05:51 PM
jhemker15
Jun 16, 2005 11:16 AM
