Need help with Code Readers
Old Nov 19, 2011 | 10:43 PM
Ddaybc's Avatar
Ddaybc
Please help as I seem to be unable to figure out how to do a search for code readers. I'm trying to find out how to determine if my truck is an OBD1 or OBD2 so I can purchase the appropriate code reader. After many searches I've only come up with frustration.
My truck is a 94 F 150 4x4 XLT Supercab with a 5.8 and E4OD transmission.
Recently my truck started to stumble at idle and while driving down the road. I want to pull the codes to see where to begin with troubleshooting.
Any help is appreciated.
Dave
Old Nov 19, 2011 | 11:06 PM
tsherry's Avatar
tsherry
Pre-96 is OBD -1 a cheap ($20-30) code reader will do the job.
Old Nov 20, 2011 | 03:40 AM
peter_x's Avatar
peter_x
Or count the MIL flashes:
Ford Ranger/Bronco II EEC-IV Testing
Old Nov 20, 2011 | 10:25 AM
Conanski's Avatar
Conanski
Your truck is OBD-1 and the Equus 3145 is a very good and inexpensive code reader for it. You can also get the codes without one by installing a jumper(paperclip) between the STI and Sig_Rtn lines on the EEC Test connector.. located on the drivers side inner fender in the engine compartment, turning the key to run, and counting the flashes on the check engine light. Note that the test light shown in the pic isn't needed unless your check engine light is burned out.
Old Nov 20, 2011 | 06:57 PM
Ddaybc's Avatar
Ddaybc
Thank you for the replies. Conanski I especially thank you for giving me the information on a specific code reader. I purchased it today and will test my truck tmo while it's daylight.
Dave
PS: How do I thank you on the forum. I understand there may be a way to do so but am not sure how.
Old Nov 20, 2011 | 08:12 PM
White 97 xlt's Avatar
White 97 xlt
Dave
In the upper right hand corner of each post you will see this button . Click it to add to the reputation of folks that give you good info...
Old Nov 20, 2011 | 11:23 PM
Ddaybc's Avatar
Ddaybc
Thank you White97. I appreciate the information.
Old Dec 17, 2011 | 02:03 PM
Coalroller's Avatar
Coalroller
does this test work on all e4od trannys? also for codes like 56 or 62 or what have you does the check engine light have to blink 56 or 62 times? lol
or does it flash like 5 times then pause then flash 6 for a 56 code then longer pause followed by 6 flashes then short pause then 2 more times for a 62 code and so on for multiple codes?
jaagen
Oct 8, 2012 02:57 PM
F450 Aaron
Aug 8, 2007 04:04 PM
malveaux0089
May 26, 2007 09:50 PM
bluene
Jun 5, 2004 02:19 PM
paco1945
1983 - 2012 Ranger & B-Series
13
Mar 4, 2004 08:48 PM
