EEC-IV code 998
Old May 25, 2007 | 12:42 PM
malveaux0089's Avatar
malveaux0089
Angry EEC-IV code 998
i have a 1995 f-150 with the 5.0 V-8. the check engine light has been on for a while and i found out how to check the code using a 6" jumper wire and watching the check engine light. i am pretty sure that it gave me a code 998 which is supposed to be a fault in the ECT/ACT/MAF/TPR circuit. does anyone know what the heck that means. i have never heard of that before. any help will be appreciated.
Old May 25, 2007 | 06:39 PM
bobcf's Avatar
bobcf
998=hard fault present. this is the dreaded "limp-mode". Extensive problems are what normally trip this code. Additional codes will be present with this code.
I would check codes again. that dosent sound right.
Old May 26, 2007 | 09:50 PM
malveaux0089
well after further investigation, doing the test "key on engine off" again, it gave me a code 22. then continuing on to the "key on engine running" test it gave me the dreaded 998 code. i found some more info on-line about the 998 code. basically it said that you must pass the "key on engine off" test with a code 11 before doing the engine running test.
Jim859
Sep 18, 2016 03:39 PM
Boofracinginc
Mar 29, 2016 07:27 AM
timalew
Aug 26, 2012 07:29 PM
Badgernorthwest
Apr 27, 2009 09:40 AM
fordtrks4fr
Oct 10, 2003 04:19 PM
