Warning Light
Old Jun 5, 2004 | 01:44 PM
bluene's Avatar
bluene
Warning Light
I have a 1989 F250 with 7.5 liter EFI engine, CA emissions, and 95K miles. Some mornings as it is warming up (after about 5 minutes) the "Check Engine" light flashes what appears to be a code 131. It does this twice and then stays off. Is this a code, and what does it mean? Thanks for your response.
Old Jun 5, 2004 | 02:19 PM
EPNCSU2006's Avatar
EPNCSU2006
It shouldn't flash a code unless you are running a diagnostic check. It probably has stored a code though, and if you don't know the process for pulling the codes, go to http://fordfuelinjection.com and click on "Getting Codes"
