Beechkid, is that mag anode you purchased from Far West part # 1S1? If so, do you remember the cost? Thanks.
They come in many different sizes .....IIRR I payed about $15, but that was back in 1997 (my last purchase) so I would guess double that now.....and I still have enough left over to build 2 more!
hey guys go check out this kit! i think its about to blow the comp away! looks to be a great set up! if your a member on the org also you will be able to see this if not ill post up another post with website info http://www.powerstroke.org/forum/6-0...r-special.html
3. I have installed a magnesium anode in all overflows
what's an overflow?
5. and best of all....there is absolutely no chance of a partially clogged in-line filter reducing the flow.
these filters we're adding are BYPASS filters, they add an additional path for the coolant. Even if the filter was allowed to completely clog, you'd be only back down to your original flow.
