Coolant filter install
Old Feb 22, 2004 | 06:09 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Post Coolant filter install
I've seen a few questions posted recently about coolant filters, so I took a few snap shots of mine to give some ideas.
Here, here, here, and here are the installation photos showing the mount, hoses and the connections.
Old Feb 22, 2004 | 06:19 PM
International Tech's Avatar
International Tech
Nice Job!
Old Feb 22, 2004 | 07:34 PM
fast freddie's Avatar
fast freddie
I like it Cookie. Where would you find a set up like that?
Old Feb 22, 2004 | 07:39 PM
cookie88's Avatar
cookie88
FTE Emeritus
Thanks.
If you're looking for a "kit" you can check out Bob Riley's website. www.dieselsitetoo.com the site is down right now, but should be up tomorrow.
Old Feb 22, 2004 | 07:48 PM
horsecop's Avatar
horsecop
Nice set up Cookie.
Old Feb 22, 2004 | 08:49 PM
F0rdF0rever's Avatar
F0rdF0rever
Looks nice Cookie. I plan on putting a coolant filter on mine soon. Did the kit come with the mounting bracket?
Old Feb 22, 2004 | 08:57 PM
cookie88's Avatar
cookie88
FTE Emeritus
No, I made that. The kit is "designed" to bolt on the side of the air box. Since I haven't had an air box for some time I needed a place to mount it that was easy to reach/maintain. I've seen them mounted behind the bumper or along the framerail on the passenger side, but I prefer not to crawl around when things are dripping.
Just drill some holes in a chunk of angle iron, and use the bolt on the top of the alternator.
Old Feb 22, 2004 | 08:59 PM
F0rdF0rever
Thanks Cookie. Im going to order mine right now. How long did the install take?
Old Feb 22, 2004 | 09:51 PM
cookie88's Avatar
cookie88
FTE Emeritus
Well, once I had the bracket made up and pre taped all the fittings the actual install took around half an hour. Figure maybe 1.5 hours total including cutting and drilling the mount bracket.
ON EDIT: Go ahead and order a couple of extra filters. My first filter loaded up with casting sand in about 3 weeks. The second one about four months later. After that it should be a once a year deal, but I'll be doing mine every six months since I've got $200 worth of last forever coolant on board.
Old Feb 23, 2004 | 08:31 AM
HeatStroked's Avatar
HeatStroked
Hey Cookie,
I bought mine at Dieselsittoo. Good to work with.
I was not about to drill holes into my new AIS intake, no way.
Even if I did, there was not enough clearance.
So, I had to fab a bracket and mounted it off the firewall on th drivers side.
Here ar 4 pix;
http://community.webshots.com/photo/...15594854KegNkJ
Old Feb 23, 2004 | 09:17 AM
CLK's Avatar
CLK
cookie,
What is the NAPA replacement filter number.
Thanks,
Chris
Old Feb 23, 2004 | 09:22 AM
HeatStroked
It only took three weeks to fill up huh?
Better go check mine.
I also ordered a three pack of the Baldwin's when I ordered the filter.
Haven't cross referenced with NAPA or Wix.
Old Feb 23, 2004 | 10:26 AM
horsecop's Avatar
horsecop
Heat do the Baldwins have the filters that have the coolant additive in them already or are they just a straight filter?
Old Feb 23, 2004 | 10:37 AM
HeatStroked
They offer both.
If you order from Dieselsitetoo, tell them which you want.
They have the filter with the SCA additive so you don't have to add as it breaks down, (supposedly).
For those PSD's with the Gold coolant it is just a plain filter.
I just changed mine out a few minutes ago, after 3000 miles on the filter and I couldn't believe the sand that was floating around in the coolant system. I could tell as soon as I began unthreading the filter, you could hear and feel the grit.
I flitered what was in the filter itself through a fine cheesecloth and there was quite a bit of sand in it.
Old Feb 23, 2004 | 10:39 AM
horsecop's Avatar
horsecop
Cookie thanks for the site you mentioned. Been needing a new Thermostat housing and Thermo. Great info. Thanks
