coolant filter?
Old Nov 2, 2011 | 01:13 PM
balzdeep05''s Avatar
balzdeep05'
coolant filter?
what would be a good coolant filter kit to go with iv seen several that clam to be good but what do y'all use and what works
thanks
Old Nov 2, 2011 | 01:28 PM
smokersteve's Avatar
smokersteve
Old Nov 2, 2011 | 01:34 PM
balzdeep05'
thanks smoker for the fast reply i think im going to go with the mkmcustoms for +- $130 with free shipping sounds good to me
Old Nov 2, 2011 | 03:37 PM
watatrp's Avatar
watatrp
Good choice. I installed one just a couple of weeks ago. Only takes about a half hour and looks great.
Old Nov 2, 2011 | 04:02 PM
balzdeep05'
i ordered the sinister coolant filtration system from mkm customs for $129 with free shipping should be here in a few days looking forward to putting it on
Old Nov 2, 2011 | 04:03 PM
balzdeep05'
well as i posted i got an email saying ill have it on the 4th
Old Nov 2, 2011 | 04:31 PM
EXbowtieguy's Avatar
EXbowtieguy
Got mine (Sinister) sitting on my bench waiting for me to find time. I must say after looking it over thoroughly I'm REALLY impressed with the quality and the look !
Old Nov 2, 2011 | 05:17 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Be sure to hook up the line BEFORE the heater control valve if you have a crew cab truck.
This:
Ford Truck Enthusiasts Forums - Rusty Axlerod's Album: coolant filter - Picture
Not this:
I got to do it twice.
ON EDIT: THE PICS ABOVE ARE REVERSED. The second pic labeled "not this" is the correct location for the T. Sorry for the mix up!
Old Nov 2, 2011 | 05:51 PM
balzdeep05'
haha ill keep that in mind rusty
Old Nov 2, 2011 | 06:04 PM
smokersteve
mine is the NOT THIS picture! why not?
What is the part number to replace the hose?
Old Nov 2, 2011 | 06:38 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
me as well
what is the difference? my filter gets hot enough to burn me very quickly. only thing I can think is that I am reverse flowing the heater core. it is still filtering coolant though. You can see it spraying into the reservoir.
but yeah, to replace that hose? If I'm wrong, I'll change it
Old Nov 2, 2011 | 06:39 PM
EXbowtieguy
This:
Not this:
Tap in on the firewAll side of the valve NOT the radiator/ grill side of the valve ? Is this correct ???
Old Nov 2, 2011 | 08:19 PM
steven06's Avatar
steven06
If your a little wrench savvy you can make your own. I went to a class 8 truck shop, bought a filter head and 3 fleet guard filters (WF2077 I think) then 6ft of 3/8in heater hose. Then to home depot for some pex fittings and a ball valve. Took it all home and fabbed up a mounting bracket. I used the instalation instructions from an aftermarket kit to make sure I knew how to hook up the lines the right way. Total cost to me was about 75 bucks, and I got 3 filters instead of 1. I used a piece of dimond tred steel that I painted black came out pretty nice.
Old Nov 2, 2011 | 08:57 PM
lenzhotrod's Avatar
lenzhotrod
I don't know if post #8 is correct. If it it then WHY?
Old Nov 2, 2011 | 09:06 PM
balzdeep05'
i think that you put the tap in b4 the heater control valve so on the side closest to the front of the truck
