1978 - 1996 Big Bronco
Needs Help With Bronco Project!!!!!
Old Oct 24, 2011 | 01:42 PM
JohnMcD348's Avatar
JohnMcD348
Are you using the original cables to attach the starter/batter/solenoid? they could be badly corroded internally and preventing the current(creating a high resistance) to start. I know I had to replace the ground cable on my 92 that had about 12-16 inches of green corrosion under the cable shielding. If the starter tests OK, check the actual cables.
Old Oct 24, 2011 | 05:04 PM
FordGirlBronco's Avatar
FordGirlBronco
I think I got it
Ok so I took my meter and the battery was reading about 10 volts. Then I put the positive on the battery and the other on the cable that goes from the solenoid to the starter. Then I put the positive on the battery and the other in the boot from the ignition switch. All read right below 10 volts. Correct me if I'm wrong but it is a battery problem right either the battery needs to be replaced again or the connections on the terminal aren't very good. Btw the battery I just put in was used it came off my old silverado.
Old Oct 24, 2011 | 07:08 PM
andym's Avatar
andym
Battery should be 12 volts when not running, 14 with the engine running. Sounds like you have a dead cell in your battery.
Old Oct 24, 2011 | 08:37 PM
JohnMcD348's Avatar
JohnMcD348
put the battery on a charger and see if it can be topped off. If not, like was said before, it may be a dead cell or just needs electrolyte replacement/water.
Scheol
May 14, 2013 05:57 PM
steakerson
May 6, 2011 01:59 PM
Sport45
Apr 30, 2007 02:44 PM
openscars
Jan 4, 2005 10:45 AM
Overfences
Dec 8, 2002 11:02 AM
