Still no start
Old Oct 11, 2011 | 12:58 AM
musclecars90's Avatar
musclecars90
Still no start
So I did a few test on my truck. Im reading low pressure oil because its reading on the gauge and my oil filter fills up with oil, Im reading high pressure oil because I did the ICP sensor test and reading 1.2 at cranking, I have fuel reaching the secondary fuel filter and did the FICM test by pushing .48 volts while cranking. I talked to a body of mine and the guy he worked for has his own shop working on these trucks and told him my symptoms. All it does is sit there and crank until the batterys die and raw fuel comes out the exhaust. He said sounds like injector o rings or brass fittings at the bottom, so I bought 8 kits and did all 8 injectors still wont fire any questions.
PS do have fuel in my tank about half a tank at that
Old Oct 11, 2011 | 09:42 AM
BLADE35's Avatar
BLADE35
Have you tried to unplug the ICP and start doubt its this one
if that dont worl unplug fan clutch at fan shroud and start
then start checking the fuses if you havent already
scan for codes
Old Oct 11, 2011 | 11:23 AM
bismic's Avatar
bismic
Was the FICM voltage test done at KOEO, or cranking, or both?
Be aware that the FICM voltage could be good and the FICM still could be bad.
What year is the truck? Any mods?
I didn't see any mention of codes either.
Old Oct 11, 2011 | 11:45 AM
musclecars90
I have pulled the ICP still no start, I will try the fan clutch. And no I have no codes being thrown. And what is KOEO? I did the FICM voltage test with the ignition on but not running, and then while cranking.
Old Oct 11, 2011 | 11:53 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Did you REALLY try to pull codes or you just don't have a Check Engine Light? You can have codes withOUT the light.
Old Oct 11, 2011 | 12:11 PM
musclecars90
I tryed pulling codes my I have two types of scanners and only pulls hard codes not soft codes. The only code that was thrown was the ICP when i unplugged it but I cleared it when it still didnt start
Old Oct 11, 2011 | 12:19 PM
musclecars90
I forgot its an 04 f-350 i have the newer motor with ICP on the valve cover. straight piped with SCT tuner
Old Oct 11, 2011 | 12:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Have you tried resetting the computer back to the stock tune?
Old Oct 11, 2011 | 03:53 PM
musclecars90
yes still doesnt do anything still sits there and cranks. the other night i got it to turn over 3 times and ran for about 5 seconds each then just cut out.
Old Oct 11, 2011 | 04:28 PM
grantpage's Avatar
grantpage
KOEO- Key On Engine Off
Old Oct 11, 2011 | 06:52 PM
cheezit's Avatar
cheezit
check for a v-ref short. chekc sync and ficm sync.
fyi we dont see to many injector o-rings going out on 6.0's
DougJ_1997PSD
Jul 16, 2017 08:50 PM
Hollywood691
Mar 9, 2015 12:37 AM
flcracker9
Mar 3, 2013 07:13 AM
mudslingur
Dec 9, 2010 08:59 PM
Seven-Point-Three
Mar 17, 2010 06:04 PM
