HELP......head gaskets???????
Old Oct 10, 2011 | 09:02 PM
ambrose2004's Avatar
ambrose2004
ive heard the terrible head gasket storys and now i need to see what i should do for this problem......
last few mornings the truck has been giving me some smoke on start up but then goes away. today drove today and it started smoking on and off mostly white but didnt smell sweet like coolant.....but i went and got 3k pounds of gravel and it ended up over heating. i pulled over and shut it down before it went into the red. i then opend the degas bottle and seemed to steem for a long while. ended up putting roughly 2 gallons of coolant to fill it up. drove home with no smoking that i noticed......
where do i start to find out if its head gaskets, egr cooler or whatever else you guys might have seen.
Old Oct 10, 2011 | 09:18 PM
BLADE35's Avatar
BLADE35
you need to park the truck Nose Down and pull the EGR valve if theres any sign of coolant then your EGR cooler sprung a leak
you also need some gauges the stock gauges SUCK
I use a scan gauge 2 great unit for 160.00
with gauges you can see what condition the oil coolers in
the oil cooler plugging is the usually takes out aN EGR cooler
Old Oct 10, 2011 | 09:22 PM
timmytoes's Avatar
timmytoes
Mine is doing pretty much the same thing. Coolant ends up low but no leaks. Runs fine until i put a load on it then it overheats. Mine ends up puking out the degas. Yours?
BLADE35's Avatar
BLADE35
If it ever gets HOT like that again pull over and let it Idel to cool down
When you get hot and just shut it off it may Cook the turbo
Old Oct 10, 2011 | 09:26 PM
BLADE35's Avatar
BLADE35
Do you have any gauges???
If you have Temp spikes that happen fast usually points to head gaskets
you need gauges to check your ECT vs EOT spread to rule out a plugged oil cooler
Have you pulled the EGR Valve out yet????
Old Oct 10, 2011 | 09:37 PM
timmytoes's Avatar
timmytoes
I'm going to try to find me a scan guage 2 tomorrow. I pulled the EGR valve today and it was pretty sooty but it wasn't wet. I cleaned it up real good but I have to go pick up new orings and gasket in the morning. When mine overheated, I pulled it over and turned the heater on and it went down almost immediately. I wish I had the guages so I could see for sure what those numbers are but I'll fix that tomorrow hopefully.
Old Oct 10, 2011 | 09:40 PM
BLADE35's Avatar
BLADE35
5. Road Test For Restricted Oil Cooler – Setup and Observations:
a. Install integrated diagnostic system (IDS) select engine coolant
temperature (ECT) and engine oil temperature (EOT) PID’s on IDS
Datalogger
b. Carefully drive the vehicle at wide open throttle (WOT) / high load to
achieve maximum boost.
NOTE
FOR ACCURATE TEST RESULTS, ECT TEMPERATURE MUST BE GREATER
THAN 190° F (88 °C) WHEN MEASURING THE ECT AND EOT MAXIMUM
TEMPERATURE DIFFERENTIAL
NOTE
PERFORMING THIS TEST STEP OUT OF SEQUENCE CAN RESULT IN
INACCRUATE TEST RESULTS. THIS CAN BE CAUSED BY A LEAKING EGR
COOLER ALLOWING (HOT) COMBUSTION GASES TO ENTER THE ENGINE
COOLANT AND ARTIFICALLY RAISING THE ECT READINGS.
c. Observe ECT and EOT PID’s on IDS Datalogger. EOT maximum
temperature differential might occur at throttle tip-out.
(1) If EOT is within 15° F (8.4° C) degrees of the ect, go to Step 7.
(2) If EOT exceeds ECT by 15° F (8.4° C) or more at any time
during the test, go to Step 6
Step 6
is to replace the oil cooler
Step 7
is to test head gaskets.
Without any additional TSB’s specifically for clogging oil coolers, the above statement
has been adopted by the community as the benchmark to determine a clogged or clogging
oil cooler. For the lack of a more in depth test process we will assume that a delta of less
than 15° Fahrenheit your oil cooler is operating within specifications. If it is above 15°
Fahrenheit oil cooler maintenance is required, which may include replacement of the oil
cooler core.
Old Oct 10, 2011 | 09:52 PM
timmytoes's Avatar
timmytoes
Thats good stuff. I'll get some guages tomorrow and report back iwth some numbers as soon as I can. Maybe that'll tell the story. I can't thank you enough for the help!
Old Oct 11, 2011 | 06:05 AM
ambrose2004
I just checked this post this morning, I will park on a hill and take off egr valve, I take it I need a new gasket/o ring? I have no gauges where do you guys get ur scan gauges at? And yes it seemed to be fine then temp shot up. I pulled over and shut it down like 30 seconds after pulling over. I just got a little freaked out its never done it before. Anyway I will pull it off after work I just wanted to make sure ill have all the parts to put it back together. THANkS for the start points guys you guys always lead me in the right direction
Old Oct 11, 2011 | 09:23 AM
BLADE35's Avatar
BLADE35
autozone or
www.scangauge.com
Old Oct 11, 2011 | 06:30 PM
ambrose2004
ok so i got the time to get the egr valve off, and it was very wet inside the intake so i figure i need to get a egr delete kit or egr and oil cooler. any idea on what route to go, or what brand/company to go with?
Old Oct 11, 2011 | 06:39 PM
BLADE35's Avatar
BLADE35
Yep your oil cooler is plugged and EGR cooler POPPED
STOP driving it till you can repair it
It may Hydrolock if you continue to drive it and you DONT want that
Old Oct 11, 2011 | 06:43 PM
ambrose2004
ok it is parked as of now, i have a co worker that said he would fix it for 300 bucks plus parts. i think thats probably worth it....
Old Oct 11, 2011 | 06:47 PM
BLADE35's Avatar
BLADE35
here check these guys out they have both a bullet proff egr cooler oregr deleate
there egr deleates look stock like its still there
Semi Bullet Proof Package
Old Oct 11, 2011 | 06:52 PM
BLADE35's Avatar
BLADE35
has he worked on these 6.0 before if so 300.00 bucks is awesome
If he hasnt played with a 6.0 before I can send you some stuff that will help
since the EGR cooler has had a catastropic failure you will have to flush the cooling system after
and a coolant filter is a GOOD idea at this point
heres a EGR Deleate that I went with its a Full EGR Deleate
http://www.mkmcustoms.com/egrdeleteandupgradekits.aspx
theres one out there thats identical for cheaper just have to watch the welds on the cheap ones I cant remember where I saw it it was like 150.00IIRC
you also may throw a CEL and may need a tuner to turn it off
