Arizona Chapter Join Chapter, Leader:
October chat
Old Oct 27, 2011 | 08:40 PM
  #286
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by 66-Ol'Henry
hmm.. could be? cause i just replaced my fuel pump also. and its the one where the arm reaches into the cam and everytime the cam spins and hits the arm it shoots in gas. i wouldnt the first clue to check for what that problem is...
and dont feel that way trey your helpin, thats all that matters
Can you check fuel pressure? I dont know how expensive fuel pressure gauges are.. I've never bought one mine was free. If they are expensive I can send you mine in the mail for like $5 for you to borrow. Its nothing special, but it works!
Old Oct 27, 2011 | 08:49 PM
  #287
66-Ol'Henry's Avatar
66-Ol'Henry
i dont know if i can, i have a pressure guage though... and the needle is always on green. i dont have awhole lot of wires and sensors all over on my truck... its from the 60's so if its not the item in itself its usually what ever follows into it.
Old Oct 27, 2011 | 08:51 PM
  #288
A/Ox4's Avatar
A/Ox4
9 ECHO 1
My gauge is a mechanical. Like this
I'm not familiar with your motor, but on mine I can check pressures post-pump/pre-filter, post filter, and at each head.
Old Oct 27, 2011 | 08:57 PM
  #289
Bdox's Avatar
Bdox
Henry, overhaul or replace your master cylinder.
Also, change your fuel filters.
After you do those two things, let us know how thing are then.
Old Oct 27, 2011 | 09:05 PM
  #290
hotroddsl's Avatar
hotroddsl
Fuel problems relating to pressure or flow not be evident at idle you hav a set of idle passages that draw file into the engine by vacuum also included in the same circuit is a set of air mixture screws that add or remove the fuel and air by changing the size of the hole air can flow through, it is not dependent on pressure like a fuel injection system but it is all vacuum operated, you have to think opposite a Fi system, what carb do you have? And yes that sounds exactly like a m/c do you have disc or drum in front?
  #291
66-Ol'Henry
i ahve replaced my fuel filter.... my fuel pump and fuel filter are in one combined part. like this
Redirect Notice
and yea, ill ahve to get under my truck this weekend and check the brake hoses and the master.
Old Oct 28, 2011 | 04:57 AM
  #292
Jigger2020's Avatar
Jigger2020
Good Friday Morning FTE AZ
Howdy Bill & Trey & Jim & ol Henry & all
Old Oct 28, 2011 | 05:04 AM
  #293
hotroddsl's Avatar
hotroddsl
I see I don't rate a hello?... That I can understand ( I'm kinda an azz) but Poor Monty is in tears with his tail tucked down! ^^^^^he won't even look at tha screen....hes all better now got a small wag
Good morn Gerry how's it going on your side of the continent?
Today I'm actually signing up to take the courses for my Masters! It's gonna be a real PITA but ve got nothing better to do why not
Old Oct 28, 2011 | 05:23 AM
  #294
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Hey guys! Its 3:21am here. I just got home. (Again) I watched a Delta II missile launch Launch was at 2:48am PST. Pretty cool stuff
Old Oct 28, 2011 | 05:34 AM
  #295
Jigger2020's Avatar
Jigger2020
HR what do you mean your name is up there, hehehe
HELLO JIM....................no direspect intended
Old Oct 28, 2011 | 05:55 AM
  #296
hotroddsl's Avatar
hotroddsl
Gerry I gotta ask how on earth did yo become a "slackmaster"? I haven't done any thing since 2007 and thought I had it mastered by now! How long have you been slacking professionally? And does it pay better than my amature slacking? These are questions I've been pondering as I'm considering turning pro! Is there a professional slackers guild I need to join? If ^so I'll try to give them a call next week...or sometime when I get around to it...you really don't need to answer these questions..as you know I'll never bother finding any more info. Ive got stuff on the DVR I need to not watch sometime...lol
Jim & the ultimate slacker...Fat Monty
Old Oct 28, 2011 | 06:11 AM
  #297
Jigger2020's Avatar
Jigger2020
Jim, you have to be nominated then voted in by 3 slackmaster members, its a tough crowd, check "social groups " under quick links at the top here, good luck
I've been retired for a few yrs & drive a school bus 2 hrs a day
Old Oct 28, 2011 | 10:08 AM
  #298
Bill W's Avatar
Bill W
Doog Gninrom Enoyreve! Yppah Yadirf!
Old Oct 28, 2011 | 10:10 AM
  #299
Bill W's Avatar
Bill W
ıʇ,s ndsıpǝpoʍu ɟɹıpɐʎ
Old Oct 28, 2011 | 10:12 AM
  #300
Bill W's Avatar
Bill W
!dnekeew Taerg a Evah .syug uoy htiw gnissem tsuj I'm .....Yako
