Sponsored by: Auxito
MAF sensor
Old Sep 24, 2011 | 06:55 PM
khadma's Avatar
khadma
Carpenter Local 745
MAF sensor
2002 F150 4.2 auto 2wd reg cab sb
Can MAF sensors just stop working? P0102
I cleaned the MAF and replaced the air filter.
I will look for leaks after the MAF and check electrical connections as
soon as possible.
The only thing is I do not have "wire piercing probes" for my multimeter,
and getting to the MAF connections in the housing looks tough.
Any suggestions to testing? I do not want to replace MAF unless I have to.
Old Sep 24, 2011 | 07:55 PM
kbsupercrew's Avatar
kbsupercrew
you could omh it at the connector underneath the filter housing signal + and ground neg wires should read open
Old Sep 24, 2011 | 07:59 PM
jeepin66's Avatar
jeepin66
maf testing
I was just looking into this on my 00 Exp. and came across this website for testing the maf on our trucks. Hope it helps.
Part 1 -How to Test the Ford MAF P0102, P0103 (4.2L, 4.6L, 5.4L).
I am going to test mine tomorrow...
Chris
00 Exp. 5.4 2wd
05 SD 6.0 CC SB 4x4
Old Sep 24, 2011 | 11:01 PM
stumprider69's Avatar
stumprider69
I usually use T-pins and slide them into the connections. T-pins being sewing style pins that have the T shaped end. Of course, you have to be careful not to peirce the wires or allow the ends to touch one another if you have more than one pushed in. I have used them several times with no problems. I use an old film canister with holes on the top to store them. Saves having to get the wire peircing probes.
B-Dozer
Modular V10 (6.8l)
36
May 23, 2015 06:13 PM
fordxl68
2004 - 2008 F150
Mar 24, 2008 03:37 PM
britt
Modular V10 (6.8l)
Nov 23, 2007 08:56 AM
Joe Finn
1997 - 2003 F150
Jan 25, 2004 03:03 PM
karmaz_payvment
Modular V8 (4.6L, 5.4L)
Sep 13, 2003 08:35 PM
