I usually use T-pins and slide them into the connections. T-pins being sewing style pins that have the T shaped end. Of course, you have to be careful not to peirce the wires or allow the ends to touch one another if you have more than one pushed in. I have used them several times with no problems. I use an old film canister with holes on the top to store them. Saves having to get the wire peircing probes.
