Modular V10 (6.8l)
MAF sensor??
Old Nov 20, 2007 | 07:19 PM
britt's Avatar
britt
MAF sensor??
Hey Guys, trying to do some maint on my 2000 f250 v-10, where is the maf sensor and how do you clean it ? carb spray? thanks-- britt
Old Nov 20, 2007 | 08:57 PM
MisterCMK's Avatar
MisterCMK
Use electrical contact cleaner rather than carb cleaner.
Old Nov 21, 2007 | 07:08 AM
IndyDog's Avatar
IndyDog
How often should it be cleaned?
Old Nov 21, 2007 | 09:25 AM
dkf's Avatar
dkf
On the stock airbox the MAF is located behind the air filter. There is a black plate that the air filter seats against, pull that out of the housing. The MAF is screwed to the plate.
I use CRC MAF cleaner I get at Advanced or Autozone. Costs about $7 a can but it made especially for cleaning the MAF. Follow the directions on the can and make shure you spray every wire good. (Thats why I take mine out of the truck) I clean my MAF twice a year.
Old Nov 21, 2007 | 09:29 AM
hydro_37's Avatar
hydro_37
Make sure to re-set the computer after cleaning.
Old Nov 21, 2007 | 10:26 AM
IndyDog's Avatar
IndyDog
Ok...umm...how's that done?
Old Nov 21, 2007 | 11:26 AM
Monsta's Avatar
Monsta
Sit. Stay.
Disconnecting the battery for about 20 minutes. You'll need to do a full driving cycle afterwards.
Old Nov 21, 2007 | 01:35 PM
bigrey6306's Avatar
bigrey6306
Good info, I probably need to do that too...
Old Nov 22, 2007 | 07:14 AM
IndyDog's Avatar
IndyDog
Full driving cycle as in fast starts, slow starts, highway/local driving?
Old Nov 22, 2007 | 07:59 AM
Fredvon4's Avatar
Fredvon4
Below is the description for a full driving cycle... I always do this on the very aggressive side to also teach the trany my driving style
If the vehicle’s powertrain system or its battery has just been serviced,
the on-board diagnostics system is reset to a “not ready for I/M test”
condition. To ready the on-board diagnostics system for I/M testing, a
minimum of 30 minutes of city and highway driving is necessary as
described below:
• First, at least 10 minutes of driving on an expressway or highway.
• Next, at least 20 minutes driving in stop-and-go, city-type traffic with
at least four idle periods.
Allow the vehicle to sit for at least eight hours without starting the
engine. Then, start the engine and complete the above driving cycle. The
engine must warm up to its normal operating temperature. Once started,
do not turn off the engine until the above driving cycle is complete.
Old Nov 22, 2007 | 09:03 AM
IndyDog's Avatar
IndyDog
Fred...so I understand completely, disconnect the battery after servicing the MAF for at least 20 minutes. Then reconnect the battery and let it sit for at least 8 hours, then complete a driving cycle as you've described above. I just want to make sure I do this in the correct fashion...thanks.
Old Nov 22, 2007 | 01:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
If you click "FULL DRIVING CYCLE" in my post above it will give you a very detailed driving cycle. Just ignore the stuff about monitoring it with Auto Tap software.
Old Nov 23, 2007 | 08:56 AM
Fredvon4's Avatar
Fredvon4
I did not see Monsta's link before...this is much more comprehensive and I strongly recommend copying his instructions and learning how to do it that way....
The quick way I posted works for me to complete the trany learning and set the 'puter for an emissions test
I am surprised that as much as I research this motor and the OBDII that I had never seen (in one place) all the steps in Monsta's link...
Learn somethingnew every day... Monsta thanks for the second post....got my attention
britt
Oct 8, 2010 08:30 AM
britt
Modular V10 (6.8l)
Sep 16, 2010 09:18 PM
britt
Modular V10 (6.8l)
Sep 15, 2010 07:47 AM
britt
Modular V10 (6.8l)
Jul 30, 2010 08:04 PM
fderflinger
Aug 21, 2007 06:38 AM
