1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Truck Moves Forward When Starting!
Old 09-22-2011, 07:18 PM
Sickler1's Avatar
Sickler1
Sickler1 is offline
I have a 2003 f250 5.4 auto...This problem only happens when it sits overnight and i start it in the morning...when i start it the truck actually jumps forward like it wants to go but only for a second....
any ideas?
Old 09-22-2011, 07:39 PM
shore's Avatar
shore
shore is offline
my 2000 did the same
I used to own a 2000 SD 4x4 5.4 auto, that did the same thing. It would only move a little. But it was enough to make me think "whoa what the hells going on". My truck only did it when it was really cold outside, and the trans was extremely cold, and parked on a flat surface.
Old 09-22-2011, 07:46 PM
Anomic's Avatar
Anomic
Anomic is offline
Make sure clutch is all the way to the floor
Old 09-22-2011, 07:52 PM
Sickler1's Avatar
Sickler1
Sickler1 is offline
Same thing...ever figure it out
Old 09-22-2011, 08:04 PM
Blue Jay's Avatar
Blue Jay
Blue Jay is offline
Re read the post. It is an automatic.
Old 09-22-2011, 08:34 PM
ken kenmnedy's Avatar
ken kenmnedy
ken kenmnedy is offline
mine hasnt done that yet....now I will have to watch out for this
Old 09-22-2011, 08:51 PM
tgreening's Avatar
tgreening
tgreening is offline
I owned my '01 for 10 years and it did the same thing. I think you'll find it's a common phenomenon and of no concern.
Old 09-22-2011, 09:51 PM
shore's Avatar
shore
shore is offline
Nope. Just learned to live with it. It never did it in my driveway on cold days. My driveway is on an incline though. I got thinking maybe when I parked at work, on the flat, maybe the park pin in the transmission wasnt engaging (if the 4r100s even have a park pin in them). And when I would start it after work, it would roll forward on start-up, until the pin caught. I don't know thats just what I was thinking. I'm probably wrong. I have an 03 now with 128'000 on the odemeter and it hasnt done it yet. My 2000 had over 170,000 when it started doing it.
Old 09-22-2011, 10:12 PM
Rongold's Avatar
Rongold
Rongold is offline
Forward Lurch
Mine does it every time I start it. Evidently, one of the forward clutches in the trans is engaged with no pressure and as soon as the engine starts to spin it disengages. I wouldn't worry about it.
RON
Old 09-22-2011, 10:37 PM
TRENT310's Avatar
TRENT310
TRENT310 is offline
Does it still lurch as much when the parking brake is used (as it should be whenever parking anywhere, not just inclines)?
Old 09-23-2011, 12:14 AM
racsan's Avatar
racsan
racsan is offline
i did see that occur once with my dad's '94 3/4 ton. the trans linkage on the coulmn under the dash had gotton loose, right where the cable attaches to the bellcrank. (lot of fwd/rev shifting, snowplow useage) and even though the seletor ws in park, the trans was really in reverse. glad i never jumpered it across the solenoid under the hood to start it. a little loctite and things tightened up, it never happened again.
Old 09-23-2011, 07:41 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Happens all the time with all kinds of trucks and cars, no worries.
Old 09-23-2011, 11:12 AM
robd928's Avatar
robd928
robd928 is offline
I only notice it when I use my remote start in really cold weather but I have a habit of putting my foot on the brake before I start it manually.
I wouldn't worry about it seems like a lot if them do it.
Rob
Old 09-23-2011, 11:27 AM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
I think its the engine cooling fan pulling the truck forward on start up
Old 09-23-2011, 11:58 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
You should always set your E-brake before putting it in park, it will reduce the load on the parking pawl in your transmission. Definitely on grades, but I set mine on flat terrain as well, just make a habit of it. Neutral -> set E-brake -> Park, every time. The only exception to this is in very cold temps on flat ground, then I sometimes don't use the E-brake so there is no concern of it being frozen in place next time I go to drive.
Quick Reply: Truck Moves Forward When Starting!
