Help!
Old Sep 21, 2011 | 08:12 PM
2wheels06's Avatar
2wheels06
Talking Help!
I have a 1995 f150 with an e4od tranny in it. I have a problem with it shifting very hard into every gear including reverse. i took it to my tranny guy and after replace the mlps sensor and the solenoid body inside the tranny and still no luck. Can someone help please?
Old Sep 21, 2011 | 08:18 PM
Edgethis's Avatar
Edgethis
Do a search on here. This is a common problem with the E4OD. There are a dozen or so sensors that affect the shifting. The hard shifting is basically the trans detecting an issue and going into a failsafe mode with full line pressure. May be time for a trans rebuild, thats what I'm getting ready to do myself.
Old Sep 21, 2011 | 08:21 PM
2wheels06's Avatar
2wheels06
thanx for the help my tranny guy put his computer on the truck and cant really get anything out of it
Old Sep 28, 2011 | 07:05 PM
2wheels06's Avatar
2wheels06
got the problem fixed it was a broken wire between the computer and the tranny. once did the scanner right got a code and ran with it. was not doing the koeoff test the tranny guy though you would get same codes by skipping to the koeon test. oh well it happens
Old Sep 28, 2011 | 10:09 PM
jq1510's Avatar
jq1510
have you checked your u joints? that makes it hit hard when you put it in gear.
smithf250
13
Sep 26, 2011 05:42 PM
juvava
Sep 11, 2011 12:20 AM
summitx670
Nov 30, 2008 02:44 AM
Pompanosix
Oct 13, 2005 06:57 PM
Carlene
Jan 31, 2004 06:08 PM
