You have a vacuum leak, but it's probably not in the grey line. The grey line will only have vacuum on it when the heater control is OFF and in MAX A/C.
You need a hand vacuum pump and gauge. Start at the pump and start checking lines one section at a time until you find the one leaking.
I've never seen a really good diagram, but it's pretty simple. The line coming off of the pump goes over to the reservoir. Next to it, coming out of the reservoir is a T fitting. A line goes towards the drivers side then turns towards the rear of the truck where it goes into the cab and to the heater controls. Another line goes towards the firewall and into a loom that goes to the pulse vacuum hublock (PVH) solenoid. The fitting on the PVH has 2 lines, one going in and one coming out. The one coming out goes back through the same loom as the other, then across the top of the reservoir and down to the hub locks. So the pump runs the heater air doors and the front hub locks.
Sometimes the PVH solenoid itself leaks, so this is something to look at. What is most likely, though, is that a line didn't get reconnected when you did the work.
Ok previously if I plugged the main line coming off of the pump it would shut down. I started disconnecting lines at the reservoir to see which line had suction. reconnected them because pump wouldn't shut off. Now when I go back to the pump and plug the initial line the pump won't shut off????????????
