Help with vacuum leak
Old Jan 23, 2013 | 05:40 PM
4x4x's Avatar
4x4x
When I bought the ex, the vacuum line under the truck was cut in half. Replaced line, vacuum pump and solenoid. The 4 wheel drive is now working and vacuum pump stops running after a few sputters as long as the a/c is turned on. As soon as the a/c is turned off, the vacuum pump turns on and keeps running.
Heater blows out the correct vents and doesn't switch to defrost whether in 4 wheel drive or not. The pump only runs continuously when the ac switch is in the off position. The pump runs every time the key is turned on.
Old Jan 23, 2013 | 06:07 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
May have a leak at the climate controls.?
Roasted7
Oct 21, 2012 06:04 PM
KrusherXX
Jul 9, 2011 07:24 PM
got2befast
Jul 6, 2011 12:09 PM
mh34444
May 29, 2010 06:40 AM
cak301
May 8, 2010 03:13 PM
