vacuum ???
vacuum ???
I am working on my 99 f-250 sd w/ 7.3 psd 4X4. Seal in the hubs are bad, so for test purposes I use a golf tee to plug them. I use my mighty vac pump From behind pass. battery fitting & the fitting near the dr. side frame leading to the lockouts, is bad,but another tee & now holds vacuum great.
I use my vac. gauge @ the pump & it holds 15-20 psi & shuts off.Good there.
I then use the mighty vac pump again @ the vacuum storage tank ??? (plumbed right after the truck mounted vac. pump) & it doesn't hold a vacuum---should it??? The solinoid that comes after it doesn't hold a vacuum when I use the mighty vac. pump on it. Should it ??? The red line off of it doesn't hold vacuum either
Are there diagrams for the vacuum lines on these things??
Sorry for the long post
mueckster, it sure does clear things up as to where things go. Thanks
Should the vacuum reservoir hold a vacuum if I apply vacuum w/ my mighty pump & have the other fitting plugged??
The same question about the PVH soleniod, should it hold a vacuum?
Is there such a thing as a repair kit/fitting for the 90 degree fitting that leads to the Dr. side vacuum hose leading to the lock out, mine doesn't hold vacuum, but does w/ a golf tee
Thanks
Thanks
xjcamaro89
2004 - 2008 F150
447
01-31-2022 07:35 AM
64F-100
16
05-04-2019 01:28 AM
granny_rocket
01-21-2014 02:54 PM
