1978 - 1996 Big Bronco
Steering wheel removal?
Old Aug 11, 2011 | 08:24 PM
Aussie_F_trucker's Avatar
Aussie_F_trucker
Hey all.
I'm in the middle of preparing my bronco for its registration inspection, which so far has been a nightmare, and I have been told the aftermarkets sports steering wheel will not pass the inspection, also it touches the windscreen wiper stalk. I actually have a stock wheel to put back on it, but I noticed the hub for the aftermarket wheel has no holes in it either side of the shaft to use a conventional steering wheel puller.
Anyone have any ideas?
Thanks in advance,
Elliott.
Old Aug 11, 2011 | 08:43 PM
b4hntn's Avatar
b4hntn
Hmmm...apply penetrating oil. Loosen nut to just slightly above shaft. Hit it with a dead blow hammer? No experience, just thinking...
Old Aug 12, 2011 | 12:27 AM
Torky2's Avatar
Torky2
I would be very hesitant to whack on the steering shaft with a hammer, would probably wreck something inside.
Try b4hntn's idea of penetrating oil, then try wiggling the wheel up and off. If a no-go, could you drill and tap the afternmarket wheel to make it puller-compatible? A puller applies push and pull forces the right way, and won't break something expensive.
Old Aug 12, 2011 | 04:22 AM
Aussie_F_trucker
Any particular product names for penetrating oil? I have a can of loctite "freeze n release".
It has a warning on a decal affixed to the FORD badge on the centre of the stock wheel saying specifically not to whack it with a hammer, so I'm kinda reluctant to lol
Old Aug 12, 2011 | 09:01 AM
jas88's Avatar
jas88
Loosen the nut enough so there is a gap between it and the wheel hub. Then set your feet hard into the floorboard underneath the pedals and press your shoulders into the seat back (you may have to move the seat up a bit). Then take both arms at 6 and 3 o'clock on the wheel, pull as hard as you can while rocking the wheel back and forth. The wheel will pop loose against the nut in short order. Seriously - I have pulled more steering wheels this way than with a proper puller.
Old Aug 12, 2011 | 11:07 AM
Aussie_F_trucker
Thanks for that, I'll give that a try first thing tomorrow. Ill let ya know how I go.
Old Aug 12, 2011 | 01:53 PM
Joseph69's Avatar
Joseph69
If Jas88's advice doesnt work, tap on the nut while it is loose while pulling on the wheel like he said. I have always just smacked the back of the wheel after removing the nut, the shock usually breaks the stuck on wheel off.
Old Aug 12, 2011 | 07:34 PM
ExtrmZ's Avatar
ExtrmZ
i had made a puller out of a sheet of scrap metal with some bolts that threaded into the holes on the side of the nut, tighten those bolts down, and the wheel pops right off. no need to go buy a proper puller
Old Aug 14, 2011 | 08:11 PM
Edgethis's Avatar
Edgethis
He doesnt have any holes on the aftermarket wheel.
Hey Aussie, why wouldn't they pass you with an aftermarket wheel? Just curious as I'm looking at swapping my wheel off for a nicer one.
Old Aug 14, 2011 | 11:38 PM
Encho's Avatar
Encho
The Southernmost Mod
Don't hit it with a hammer, down the steering column are a bearing and a u-joint which won't be very happy if you do.
papazig4726
Jan 23, 2015 05:47 AM
john fin
Mar 14, 2009 07:46 PM
oem78
May 4, 2005 11:25 AM
bocephus_3349
Feb 10, 2005 11:04 AM
Trail Master
Jun 12, 2004 08:33 AM
