splined steering wheel vs. a flat spot wheel
79-older only had 1 sleeve in the tie-rods,you have to R&R the wheel to get it straight.80-up had 2 sleeves in the tie-rods,so the wheel can be centered with the tie-rods.There not interchangeable,but I've heard of people filing the flat spot to round it off and using on the older shafts.BUT I WOULDN'T DO IT.
What does the tie-rod have to do with splines on the center hole of a steering wheel ? Both steering wheels are identical except for the flat spot, I have heard you can still install a 80-86 on a 78-79, the shaft splines will mesh into the flat spot when the nut is tightened, What would be the problem ?
