CCV Delete
Old Aug 6, 2011 | 03:27 PM
Piolet's Avatar
Piolet
CCV Delete
I've read lots about the ccv reroute but I didn't find anything obvious on FTE about a delete. When my new turbo goes in, or maybe sooner I'd really like to delete this thing.
My cummins vents to the outside air and I think the international version of this engine does too (I think I read that somewhere?)
I was thinking of doing something similar, with a small ccv filter added to the end of the hose to address suction back towards the crankcase.
I saw this thread on powerstroke.org.
Questions and Comments about the CCV reroute - Ford Powerstroke Diesel Forum
Any comments on this set up from those in the know?
Bismic, I know you've looked at the ccv issue a good deal and I've seen your racor set up, but that's a pricey filter, even the next size down is $300 if I recall. Any thoughts on the small filter?
Thanks.
Old Aug 6, 2011 | 06:04 PM
gjnicholas's Avatar
gjnicholas
I routed mine to the tail pipe been like that a little over a year and had no problems yet
Old Aug 6, 2011 | 07:34 PM
wulfman's Avatar
wulfman
Mine is a 1" hose to the rear axle does just great.
Old Aug 6, 2011 | 07:44 PM
bismic's Avatar
bismic
Sounds like quite a few folks have had good luck w/ the open ended hose. I know on the Org, many folks have installed a smaller filter (and hose) - I have seen no posts of any problems. I am still glad I went the route I did, but it was probably overkill ...
I would still recommend using a 1" hose though - and do not create any low spots where a water pocket (condensation) could form a restrictive plug.
Old Aug 6, 2011 | 07:55 PM
Piolet's Avatar
Piolet
Thanks.
I think now I'm going to do the 1" hose to the rear .. with a small filter.
What have you guys used to seal the hole in to the air intake before the turbo?
Old Aug 6, 2011 | 08:44 PM
wulfman's Avatar
wulfman
Piolet i cut a piece of plastic 1/8" thick , cut piece off filter tube to a flat area and used epoxy the fasten it on ,its still there . And 1" hose, napa only place i found it and its not cheap . but as bismic said it got to run down hill all the way , no ups
Old Aug 7, 2011 | 11:58 PM
jimmyv13's Avatar
jimmyv13
Is it 1"ID or OD tube?
Old Aug 8, 2011 | 06:05 AM
npccpartsman's Avatar
npccpartsman
At least 1" ID like heater hose. You don't want ANY backpressure on the crankcase or you WILL have running issues.
Old Aug 8, 2011 | 10:41 AM
steelhead2's Avatar
steelhead2
I used a pvc cap and a hose clamp on my intake.
Chance_Thomas
Nov 8, 2010 07:24 PM
pctjk
Aug 31, 2007 12:27 PM
79_250RangerLariat
18
Mar 8, 2006 07:52 PM
foxracer800
Feb 28, 2006 09:18 PM
blessteve
16
Nov 2, 2005 01:33 PM
