Head Gaskets
Old Aug 7, 2011 | 07:41 PM
seth1's Avatar
seth1
Head Gaskets
Do you think these would be any good?? seem to cheap and wouldnt want to skimp there..
RCD 6.0L Ford Powerstroke Black Onyx*TM Head Gaskets | eBay
Old Aug 7, 2011 | 08:06 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The stock Ford gaskets are OK to use......but you want the ARP studs.....
Old Aug 8, 2011 | 06:15 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX
Yes
I used them. No problems. That seems to be a great price for them. I think I paid right at $200 for mine.
Old Aug 8, 2011 | 07:24 AM
bismic's Avatar
bismic
Here is a post from a mod on TDG:
I'm on my second set of Black Onyx gaskets. The first set lasted 8600 miles. When Dan pulled the heads off again he said it appeared that the gasket material was defective around cylinder #5. The maker of BO said they would only cover the gasket, none of the labor involved to replace it.
I had the heads milled the first time, and they were checked again the second time, along with being magnafluxed for cracks. The heads were perfect and the studs nuts were still torqued to spec. The Ex has never towed in our possession and we were running a mild tune that was written for us when we still had the bolts in.
When I do the studs, I will go w/ OEM gaskets. Many people making well over 500 hp still use the OEM gaskets.
Old Aug 8, 2011 | 08:44 AM
TheBestKindOfEX
who knows.....
Everyone has a different experience with any part and any installation. It's like asking someone what contractor to use for a job, one has a great experience and the other a disaster. Regardless ARP studs are a must.
I don't use a tuner but I pull a heavy travel trailer. I have about 10k miles since the HG replaced. I hope it lasts a loooong time.
Old Aug 8, 2011 | 11:35 AM
texans's Avatar
texans
I would stick with OEM. Heard of to many failures with black onyx. From what I have read a lot of the people that work on these things daily have stopped using/sailing them.
ehgeeray
Dec 4, 2010 07:14 PM
1969Highboy
Jun 8, 2009 01:57 AM
johnsf
Mar 29, 2009 03:22 AM
73FOMO
Nov 28, 2006 05:47 PM
ford_nut
Jan 15, 2003 01:43 AM
