new shocks
Old Jul 23, 2011 | 08:43 PM
abe's Avatar
abe
new shocks
I ordered new shocks today from NAPA: $18.95 each. Carpenters lists them for $44 each plus shipping. NAPA had 2 in stock and had 2 order 2 from their mid-state warehouse. Not bad. I guess it will improve my ride and my Mrs. won't complain as much when we hit a bump...
Any tips or do's or don't's before I put them on...
thanks!
Old Jul 24, 2011 | 07:38 AM
f100 1957's Avatar
f100 1957
yes, last tip, change the padding of the seat in case the roads would not be in good condition.
Old Jul 24, 2011 | 09:41 AM
Bessie's Avatar
Bessie
Abe, I found the old washers to be a problem. Mine were worn through and just bearly there at all and, unfortunately, new ones did not come with the shocks I recently purchased.
I had the same experience with price -I paid about $21 for each. I've found that sometimes I get so used to going to the "speciality" providers that I forget to check with the local parts store first.
Old Jul 24, 2011 | 09:48 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I've been checking into shocks for my truck, as the AutoZone-sourced Gabriel Red Ryders are woefully inadequate. The AZ/Gabriels don't have the same specs for compressed length and extended length as the stockers. They "fit" but look to be out of their design range. It looked to me like the NAPA shocks might be the same, but NAPA couldn't give me any specs. For one thing, the Gabriels let the axle drop down further when you jack the truck up by the frame, enough that the brake hose would be pulled apart if not disconnected (kind of a drag!). I've been suspecting that the shocks offered for BB's are really the mid-fifties shocks. Could you measure the compressed and extended eye-to-eye distances? (only care about the fronts) Would appreciate it!
Old Jul 24, 2011 | 10:12 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Does any one know where to buy Bilsteins for our old trucks?Someone had told me they were making them,I was surprised, but after upgrading the ones on my wife's car to Bilsteins,I am sold on the quality difference,even over KYB's.Is it just a rumor about them?
Old Jul 24, 2011 | 10:46 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Not for BonusBuilts, I found some that are close to the specs, with the right ends. Believe it or not, Koni also makes some adjustables that could be made to work for the front of 48-52, maybe 53-56, just don't gag on the $250 price tag! (EACH)
Old Oct 17, 2011 | 08:43 PM
jrfiero's Avatar
jrfiero
Ross -
Do you have the extended/compressed lengths for stock shocks? The NAPA site has the extended and compressed lengths for thier shocks, but I don't have stock numbers to compare with.
Thanks,
Jonas
Old Oct 17, 2011 | 09:12 PM
ct50f1's Avatar
ct50f1
I'm not to the point of buying new shocks but I was wondering if anyone knew of a source for the long shoulder bolt that goes through the frame ('50 F-1) for the upper rear mounts? One of mine is pretty corroded and the large washers are messed up.
GoldenDomer
Mar 28, 2019 05:53 PM
mericanwit
2004 - 2008 F150
13
Sep 21, 2018 10:40 AM
Thegerman618
Aug 8, 2010 07:51 AM
Hobbybigred
Dec 13, 2007 02:43 PM
JBronco
1978 - 1996 Big Bronco
29
Mar 24, 2005 11:59 AM
