I have a 2004 6.0 that loose's power when pulling a long hill? Any sugestions please...Have changed fuel pump and fuel filter...computer not coming up with any codes
I heard a fella just today talking about the same issue. said the truck wouldn't pull a wet hen off the nest. Pulled the cat and it was clogged. Just a thought.
Dave
you could try this
just back the 2 bolts off right before the cat in the exhaust and see if it helps
You have two threads going at once on this same issue. It might be helpful to close one ane keep the other active. Having said that, have you checked out the Tech Folder thread as suggested?
