I did some towing yesterday
Hi all,
Yesterday was my move day and all my friends were at work, so there was no one to drive my little car to the new apartment. I went to U-haul and bought a hitch and ball and rented a tow dolly. I had already packed the bed of the truck with stuff and the car with mostly weapons. Yeah, I have A LOT of guns.
While driving, I knew I was towing something and while braking, I really knew I was towing. She made it, though.
Not just when towing but I am noticing some smoke when or if I accelerate off the line quickly and shaking at idle. My plague seems to be back. It shakes more if I am in gear. If I put it in neutral, it shakes less. I got a pulse timing adapter and #1 line from Oreo, so I can try timing it again. Thanks buddy!
The IP and injectors are the old set. I have not installed the new ones a second time. The first time I did, there were some unknown to me issues and I wound up reinstalling the old set. I marked the old pump before uninstalling and reinstalled it at that same mark. I think it is timing related. I think the pump is severely retarded. I got the timing adapter and lines installed this morning. I threw the meter on it and it read -3.2 degrees. I advanced it a dime and a half and now it reads 1.1 degrees. I did set the meter to -20 degrees offset before plugging in the cables. Just to be double sure, it should be at 8.5 not -8.5, right? I don't want to blow a head gasket.
Check ths out: https://www.ford-trucks.com/forums/3...mp-timing.html
on
yes thats right.now that your timing with the pulse adapter,you will not be using the -ATDC,but the BTDC.
i knew all along you where being WAY to conservative on your timing.
make her rattle a little already would ya.
your going to find a WHOLE NEW ANIMAL under the hood once you advance that thing already.
it's a wonder the thing got out of its own way,let alone hauled some weight and towed a car! i sure hope you didn't have any hills.
man,you should put your new ip and injectors back in first,and then time it.
you'll think you just installed a whole spare engine in there.
I advanced it another dime's worth yesterday and the meter read 0.00. It might have been a negative 1.1 the first time. I took it for a test drive and it seems to smoke a light haze even on normal acceleration. It is probably still too retarded but I can't move the pump any more without loosening the lines on the bottom. The temps were normal during the drive so I will leave it like this until I install the new stuff again. The good thing is I don't notice much shaking at idle any more. I better order that injector I need.
This site has the cheapest price on a single injector. Has anyone done business with them before?
Diesel Care Inc
Also, is there a place where I can buy just the o-rings and washers? I don't need the lines, mine are new.
Diesel Care Inc
Truck Guy99
05-27-2014 01:14 PM
