Carb Identification...
Old Jul 15, 2011 | 03:48 PM
1andonlywhitie's Avatar
1andonlywhitie
Alright the truck stumbles a little bit after fixing almost all the core components, the main thing left to do is tear down, clean and rebuild the carb. And thus I hit a problem... What model carb do I have? I thought it would be a Stromberg but after a little research I seem to think it's a Holley92. I've put some pictures so you experts can chime in!
Old Jul 15, 2011 | 05:38 PM
r_reed's Avatar
r_reed
by no means an expert but trying to bump your thread to the top. how about a ford holly 94??
Old Jul 15, 2011 | 06:33 PM
1andonlywhitie
I think it's a Ford Holley 92 or 94... Just gotta get it off and pull it apart I think...
Old Jul 15, 2011 | 11:17 PM
wmjoe1953's Avatar
wmjoe1953
Looks identical to the Holley 94 I just rebuilt for the 54. As far as I understood it, they all used a Holley 94.
Old Jul 16, 2011 | 08:33 AM
38 coupe's Avatar
38 coupe
You have a mixed up batch of parts. The top is a pre - World War 2 piece, this can be determined by the vertical oval shaped vent slot that can be seen in the first and second pictures. This top will not let you use the improved 8BA style spray bars in the center section of the carburetor. I think your center section is a 56 truck unit. The 56 cars with 272 engines had automatic choke, and the truck carbs had the blanked off passage for this. The base may be a 48 and earlier unit too, from the looks of the hand throttle linkage. If it is a pre 49 (pre 8BA) base you will not have the passages in the base to work with the vacuum advance passages in your center section. I took your top picture and pointed out the areas of interest. I think you should find a correct 8BA carburetor. If you have a truck air cleaner you can find a correct 8RT carb.
Old Jul 16, 2011 | 08:47 AM
r_reed's Avatar
r_reed
i'm impressed. the knowledge base and willingness to help of FTE members is invaluable.
Old Jul 16, 2011 | 12:07 PM
1andonlywhitie
Me too. That info is stuff I never would have found on my own...
Old Jul 16, 2011 | 03:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You're also missing the choke cable bracket, available from Vintage Speed
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
RussEx
Feb 9, 2015 09:05 PM
Bayer-Z28
Apr 29, 2010 07:40 PM
ajorn
Mar 2, 2010 01:26 PM
intensecaraudio
Aerostar
Jan 1, 2008 03:01 AM
