Some Parts Help Please
Old Jul 11, 2011 | 09:51 PM
spongecop's Avatar
spongecop
Semper Fi
I need some assistance with a couple misc. parts please: My truck has factory a/c if it matters. Stock 300
  1. Alternator: what amp alternator came on my truck - 60? The reman on it now does not have any markings but it does have the two prong plug that has the tines perpendicular to each other on top.
  2. Distributor O-ring: Have not been able to fine one for the 300. Many places list the V8 distributor part. Does this distributor have an o-ring, or is the gasket at the hold down?
Gracias,
Old Jul 11, 2011 | 10:28 PM
ctubutis's Avatar
ctubutis
Either 40, 60 or 70.
Since you have AC, 60 or 70.
  1. Distributor O-ring: Have not been able to fine one for the 300. Many places list the V8 distributor part. Does this distributor have an o-ring, or is the gasket at the hold down?
E3TZ-12143-AMR "O" RING (SEAL) Fits 1980/ 6 cyl 300 cid engines.Not available separately, serviced only in 12127 distributor assembly.
Your only hope is aftermarket; I would first try NAPA, then Car Quest, then a speed shop. Failing that, go online to maybe Summit Racing, maybe eBay.
Failing that, a hardware store.
Old Jul 11, 2011 | 10:31 PM
spongecop's Avatar
spongecop
Semper Fi
I wonder if the V8 o-ring is similar in diameter?
Old Jul 11, 2011 | 10:39 PM
ctubutis's Avatar
ctubutis
I have no idea; they have different part numbers but no measurements.
Old Jul 11, 2011 | 10:48 PM
ctubutis's Avatar
ctubutis
I just noticed something.....
The part number of the O-Ring that fits ALL (up to 1989 at least) 8-cyl engines is B9TF-12143-A.
B9..... This part has remained the same since 1959.....
Old Jul 11, 2011 | 11:02 PM
spongecop's Avatar
spongecop
Semper Fi
Boggles the mind why its not available.
Old Jul 11, 2011 | 11:06 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Yet the dist itself varies between different engines......
Must be the length only, since the OD of the housing where it meets the intake *must* be the same, if the o-ring/seal is the same.
Very interesting......
Old Jul 11, 2011 | 11:18 PM
spongecop's Avatar
spongecop
Semper Fi
since its only 2$ I guess it's worth the gamble
dukie1877
Nov 22, 2011 09:10 AM
Dreamermc
1997 - 2003 F150
Dec 11, 2009 01:02 AM
F350-6
36
Mar 22, 2008 11:19 PM
MikeSDK
Oct 13, 2006 07:35 AM
351 power
Jun 11, 2003 12:17 PM
