I have used an 88 block for a truck that is wired to use points. When I tried to install a rebuilt 73 distributor for 351w it did not fit. One of the rims below the O-ring, part of the main casting, is slightly larger in diameter. Would it be possible to machine this section of the casting to achive fit? Will the oil pump drive shaft match from 73 to 88? The drive gear is a match. A suggestion for a possible, reasonably priced, electronic alternative would be greatly appreciated if this rebuilt distributor proves to be incompatible. Thank you.
better check that again, 351 c and w distributors differ more than gear. try swapping one into the other.351 c will fit 351m, 400m 429 and 460
351w fit 351w thats it
The distributor that I had ordered did have the small gear, same as a 302, and also has the larger hole for the 351 oil pump drive. The only catch, is the casting that houses the components at the point where the casting drops into the block.
HEY SECRETE GOAT, its time to eat CROW!
ECARTER, YOUR ABSOLUTEY RIGHT. PULLED A 351W AND A 400 DISTRIBUTOR AND COULD ONLY FIND 2 DIFFERENCES,
1 DRIVE GEAR
2 THE HOUSING DIAMETOR IS .06" SMALLER ON THE 351W
YEP I'M EATING CROW AS YOU READ THIS
ITS YOUR TURN GOAT!
Thanks for your help guys. I have now recieved the correct distributor for the 351w. It is installed but not running yet. I think that the rings are stuck a bit, not allowing compression to build. A bit of oil perhaps...
