Thanks, that boost my confidence. I'll keep my eye on it for sure. However, I would still like to switch over to ELC and do a flush. For those who us ELC, how often are you doing flushes? From what I've read on here ELC is good for like 300k, wasn't sure if flushes were still required?? Thanks again for the info fellas.
check the coolant in my sig its supposed to go for 600,000 just needs a additive at 300,000
would I ever let it go that long NO WAY 100,000 is what im going
as far as a flush if I were you I wouldnt chance it just drain and fill if you want to change to elc
theres been to many cases where the good old flush plugged the cooler up
as long as the 2 deltas are ok drain and fill if it starts plugging then you could try a flush with some cleaners in it
Thanks, I am a little scared of the vc9. However, if using the vc9 clogs the cooler I think your just uncovering the problem earlier.... it was going to clog anyway......I guess I'll be cautious anyway..... Thanks again
