gauges
Old Jun 21, 2011 | 02:59 PM
6.9idiatsturbo's Avatar
6.9idiatsturbo
gauges
can somebody tell me how to hook up a boost gauge. i have a pyro gauge i know it is hooked up on the side of the turbo. but how do you hook up a boost gauge
Old Jun 21, 2011 | 06:45 PM
94 smokin stroker's Avatar
94 smokin stroker
What turbo sytem do you have
Old Jun 22, 2011 | 06:50 AM
NorthernDiesel's Avatar
NorthernDiesel
Yaa, your turbo may have a location for the pressure line. Let us know which one you have.
Generally they are installed in the pressure chamber (the piece between the turbo compressor and the intake). If you want a new install, drill and tap the chamber for a small brass NPT to compression fitting. The air line to the boost guage should run from there.
Don't do it on the engine, obviously (wash the metal filings carefully out of the chamber before re-installing)
Old Jun 22, 2011 | 01:57 PM
6.9idiatsturbo
i have an ats turbo
Old Jun 22, 2011 | 08:12 PM
84-6.9L's Avatar
84-6.9L
There may be a pipe plug in the intake snail. Thats the way my hypermax is set up, so it's a place to start.
Old Jun 22, 2011 | 08:16 PM
Coalroller's Avatar
Coalroller
you might wanna relocate your pyro gauge bud for better results to your exhaust manifold ( just my $0.02)and like the hypermax, the ats 093 series has a port for you to screw in the brass fitting as well it is right to the right and towards the front of the center bolt that hold the intake hat to the intake itself
Old Jun 22, 2011 | 09:16 PM
94 smokin stroker
It has a square head on it and looks like a plug right in the middle of the flat spot on the snail take that plug out and hook it up
Old Jun 22, 2011 | 10:54 PM
wreckinball's Avatar
wreckinball
yep its 1/8" npt so get the appropriate fitting or the kit might come with it.
johnd7854
13
Dec 18, 2009 10:11 AM
kupaa
Feb 10, 2008 06:07 AM
pip-clark
16
Sep 7, 2007 09:44 PM
Gage2502
Modular V10 (6.8l)
Feb 25, 2006 11:42 AM
TERSEJR
Feb 15, 2005 03:47 PM
