where to hook up boost gauge?
02-09-2008, 09:50 PM
on
Where do i hook up or splice the tee fitting for my boost gauge.Thanks guys Chris
02-09-2008, 10:02 PM
Easiest is to install it in the MAP sensor line. More elegant way is to pull the AIH and put in a plug with a fitting for the sensor tube.
02-09-2008, 10:04 PM
Of the next Riffraff East
I used the AIH delete plug with boost fitting that Pure Diesel Power sells.
02-09-2008, 10:49 PM
I put mine here when i had the manifold out for some smoothing of the cast marks and to paint. I also moved the MAP sensor inlet there, so they kind of get "ram-air" effect from air flow leaving the compressor.
02-10-2008, 01:44 AM
on
thanks guys,but i just cut the line from the oba and put a tee in there ,i hope that works.I will change it later because it looks much better the way you guys have it hooked up.Chris
02-10-2008, 06:07 AM
That's the way I did mine, and I just snug it up every other oil change or so. Six years and no trouble with it yet.
Austin
mattwoodsd
09-14-2016 05:50 PM
264WSM
01-28-2012 02:06 PM
johnd7854
13
12-18-2009 10:11 AM
getnbz
25
09-22-2003 08:53 PM
tommyboyf350psd
05-27-2001 02:32 PM
04,
60,
60l,
73,
aftermarket,
boost,
diesel,
f250,
f350,
ford,
gage,
gauge,
hook,
location,
powerstroke
