Fuel Pressure?
What are your thoughts on the heater throttle body? Heat it or not?
The EGR also aids in allowing for a leaner fuel mix. The 2 together can add a noticable difference in MPG.
Gary, after learning about the AIR not effecting air/fuel ratio, I might just leave it off for now. The motor seems to be running fine after the fuel pump replacement. I need to figure out why the new pump is so loud. I bought a filter during lunch and will install it after work before i head home. If that doesn't cure it, I might need to get a new in tank pump.
Are there any other filters or screen that I need to check before replacing the in tank pump?
The only problem I forsee is when the computer switches from cold start to normal operation. When the engine is cold and first started in the morning it's pumping air up stream of the O2 sensor, so the computer can detect that. The problem I see is when the engine switches from cold to normal operation, the computer will not sense the proper change in the O2 reading, thus throwing a code. Will this be enough to keep the engine from going into closed loop? Not sure. The computer right now is telling you the highest priority code is the Code 44. I don't know of any other way to get rid of that code other than to fix it properly. People are saying to hook your TAB/TAD solenoids back up, and that will work, so try it and see what the computer says.
Definately run the codes again. and each time you change something.
So. I installed a new fuel pump last night. That seemed to help out or cure my hesitation. This morning the same noise came back from the new fuel pump. I installed a new fuel filter thinking it could be clogged. That didn't help. What is my problem? In tank pump? Fuel selector valve not functioning? Any experts out there?
The IAC may be part of the issue where it dies right after starting. And, once the A/C is hooked up you'll need it to work properly to get a good idle.
If the TPS has a bad spot in the range it would probably cause a problem at some point in the throttle range. However, that code might have been operator error.
Once you find the basic part number in the Illustration section, you then take that to the Text section and look it up there.
It's more or less organized the same as the Illustration section.
Well, not really always, but the concept is as so:
The sort order is kinda like UNIX numerical sorting in that it's based on *columns* rather than natural counting.
For example, here is a directory listing of a bunch of empty files with numerals as their names (pay attention to the RH column):
chris@0024e844a672:/tmp/ct$ ll total 8 drwxr-xr-x 2 chris chris 4096 2011-06-22 17:55 . drwxrwxrwt 17 root root 4096 2011-06-22 17:55 .. -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 1 -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 11 -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 1111123456 -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 12 -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 2 -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 3 -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 33 -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 4 -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 44 -rw-r--r-- 1 chris chris 0 2011-06-22 17:55 5
1 is less than 11
11 is less than 1111123456
1111123456 is greater than 12
Then, why is THAT considered a "sorted" list?
Follow your eye down the LH column, you'll see everything increments top to bottom.
Next column over, same thing.
Same thing over and over again, left to right.
Follow the columns.
Here's another example:
chris@0024e844a672:/tmp$ ll total 72 drwxrwxrwt 17 root root 4096 2011-06-22 17:55 . drwxr-xr-x 21 root root 4096 2011-06-02 20:50 .. drwxr-xr-x 2 chris chris 4096 2011-06-22 17:55 ct drwx------ 2 chris chris 4096 2011-06-22 06:11 .esd-1000 drwx------ 2 gdm gdm 4096 2011-06-22 06:11 .esd-112
Because the 0 in the second column is less than the 1 in the second column below it.
Ford's system is based the same.
If there is an alphabetical character in the midst of numbers (e.g. 12A345) then the A-Z stuff will iterate FIRST, before the sort order takes the next highest number into account.
In any case, scroll down through the Text section and focus your eye generally in the middle of the page where the basic part number is contained.
Find the section dealing with the basic part number you're looking for, these sections are generally organized by vehicle type (model) but not always; for example, sometimes it's based on engine family, or AC compressor size, or whatever.
Anyway, you then find the vehicle onto which the basic part number fits, and, generally in the middle-ish of the page, you'll find the replacement part number.
Replacement part numbers prefixed with a black star have been obsoleted and not replaced; good luck finding those at a retailer anywhere.
Sometimes, off in the RH side, you'll see something like:
#E4TA 12345 - HA
That hash (pound sign) and what follows is what the part itself is marked as (IOW (in other words for you
) the Engineering ID number.)Only sometimes will they do that.
Another example - a comma means "or":
E6TA 9J338-AA,AB (Text section 93 Page 18)
That means one can use replacement part numbers E6TA-9J338-AA or E6TA-9J338-AB
Once you have the replacement part number, well...
Ideally, you'd first look it up in the OSI (Obsolete/Supersede/Interchange) manual to see if the part number has been replaced but I don't have one, NumberDummy is the only one I'm aware of who has that (on microfiche).
Once you have a part number, you can then plug it into Ed's site (www.partsguyed.com) and/or www.partsvoice.com to see who has it for sale.
General classifications:
A = Aerostar
B = Bronco II
R = Ranger
E = van
F = light-duty truck
U = Bronco
Years....
80 means 1980 model ONLY
80/ means 1980 models thru the end of the catalog series (1989 in this case)
82/83 means 1982 & 1983 models ONLY
I think that's about all.
See why you need to talk to NumberDummy?
Here is a list of components & section numbers Bill gave me some time ago:
(sigh) It's a piece a cake readin' a parts catalog, cuz Ford has used the same basic part numbers since Model T days, adding new basic numbers since for newer stuff not found on T's.With Ford, the group number is the same as the basic part number. If you can count, you can use a parts catalog. If a cluck like myself can figure it out, anyone can!
Take the basic part numbers found in illustrations, waltz over to the text to get the complete part number.
Chassis Parts Sections ~ Text & Illustrations, column left: (Hipo left out what these (and the Body) sections are referrin' to .. making the catalog difficult to figure out, so here they are).
10 = Brake drums and etc.
20 = Brake shoes and etc.
30 = Front suspension, steering and etc.
40 = Rear Axles.
50 = Frame, Exhaust, Sway Bars, Springs.
60 = Engine parts.
70 = M/T parts.
A70 = A/T parts.
80 = Cooling, grille.
90 = Fuel.
100 = Alternator, battery.
110 = Starter.
120 = Dizzy & related parts, ignition modules, PCM's.
130 = Lamps.
140 = Wiring.
150 = Wiring, clocks, misc other jazz.
160 = Front Sheet Metal / Rear fendera and related parts for Duallies, Flaresides.
170 = Speedo, speedo drive and driven gears, jacks and related parts.
180 = Heater & Radio.
190 = A/C.
Body Parts Sections ~ Text & Illustrations, column left:
000 = Body mounts.
200 = Door internal parts, quarter panels and etc.
400 = Bed parts (99 is a Styleside / 83 is a Flareside). You have to add the two numbered body style to the 5 or 6 digit basic number. Example, basic part number: 27846 R/S Q/P = 9927846 Styleside.
500 = Roof panels.
600 = Seats, seat belts.
Sheet Metal.
Soft Trim.
Exterior Mouldings.
And, if you're still having trouble figuring out the little darlin, pass along your phone number. I'll call, waltz you thru it.
This wouldn't be my first time doin' this jazz, Lariat 85, ctubutis, members of myriad other forums have been waltzed thru it.
The Gallery here shrink images quite a bit, the Album not so much (although still shrinks some).
This is why I put my "bigger" pictures on a hosting site and just source 'em from there.
