Sponsored by: Real Truck
Torque App Ford Extended PIDs
Old Apr 3, 2012 | 09:28 AM
  #46
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Don't know what changed with my boost readings. They were acting weird. I'm trying to locate if I did something to change it, but it now works.
Old Apr 16, 2012 | 07:32 AM
  #47
nitrogen's Avatar
nitrogen
any idea what to change so it actually reads boost higher than 20 psi
Old May 26, 2012 | 06:00 PM
  #48
Will Bite's Avatar
Will Bite
Does anyone have the MAP code worked out for this app.
Old Jun 28, 2012 | 06:14 PM
  #49
rvfixn's Avatar
rvfixn
Android Torque PID Setting for Cylinder 9 and 10
Originally Posted by JESTERxHEAD
I have created these, please take a look and log them in your phone, share with the class on the values you get.... enjoy....
CYL #7 Cumulative Misfires
221614
7CM
0.0
100.
X1
MISFIRES
((A*256)+B)
CYL #8 Cumulative Misfires
221615
8CM
0.0
100.
X1
MISFIRES
((A*256)+B)
AUTO
Hi -
Does anyone happen to have the settings for Android Torque for Cylinders 9 and 10?
I guessed 221616 for cylinder 9, but I'm not sure. 221617 doesn't work for 10.
Thanks - bret
I have a 2000 Ford E450 RV. It has the V10 in it.
Old Jul 21, 2012 | 12:06 AM
  #50
JonnyP_03's Avatar
JonnyP_03
I'm getting a a reading of 30.0 on the FPDC, is that normal?
Old Jul 21, 2012 | 06:41 AM
  #51
Will Bite's Avatar
Will Bite
Smile
Mine reads 100% all the time don't know if its right or not.
Old Jul 21, 2012 | 06:49 AM
  #52
nitrogen's Avatar
nitrogen
Refresh my memory what is FPDC
Old Jul 21, 2012 | 07:46 AM
  #53
JESTERxHEAD's Avatar
JESTERxHEAD
Fuel pump duty cycle
It should read 100% when running
Old Jul 21, 2012 | 07:49 AM
  #54
JESTERxHEAD
Originally Posted by rvfixn
Hi -
Thanks - bret
Run the torque scan feature and email me the log I can try to give it a shot.
Old Jul 21, 2012 | 08:19 AM
  #55
Will Bite's Avatar
Will Bite
Talking
Fuel Pump Duty Cycle
Old Jul 21, 2012 | 09:27 AM
  #56
AZwhite350's Avatar
AZwhite350
So I got the ELM 327 and the torque app. Originally, the EOT readout only read 32 degrees. Then I put in a new equation and it read over 300 degrees. I finally put in the correct equation (it's amazing what a + sign will do when it is supposed to be a - sign).
It looked like it was reading OK, but I was getting very high EOT-ECT deltas - like 20 - 25 degrees. Anyway, last week, I took the truck to the Ford dealer and had them check it out.
I travel for work almost every week - and I hadn't heard from the dealership, so I called them. Thank goodness for extended warranties - the oil cooler was plugged, so they are replacing the oil cooler and EGR cooler under warranty.
So I am feeling like I dodged a bullet thanks to the ELM and the Torque app. When I say I travel for business, I mostly drive and usually take the truck. Many of the plants I call on are way out in the boonies. I do not relish the thought of my truck dying 60 miles from the nearest town when it is 110 degrees outside. That would not be a fun situation.
Old Jul 24, 2012 | 12:50 AM
  #57
AZwhite350's Avatar
AZwhite350
I picked the truck up from the dealer today. My SA said the truck was pretty close to grenading. The EGR cooler was leaking exhaust gas into the coolant loop, and had split the degas bottle. The coolant temps and oil temps were running high. The next symptom would have been the check engine light and a truck stopped by the side of the road - blown head gaskets.
Needless to say, the $40 I spent on the ELM and the Torque app was well worth it. The thought of being stopped by the side of the road out in the middle of nowhere with no cell phone service is not pleasant. And I would not have known about the problem until the truck grenaded without the ELM, etc.
Old Jul 24, 2012 | 12:56 AM
  #58
amdriven2liv
More proof how much we need to monitor our motors.
Thanks for sharing!
Old Jul 24, 2012 | 08:45 PM
  #59
JonnyP_03's Avatar
JonnyP_03
By using this app I just found out my FICM is gone to sh**! I'm glad I got those extra PID's because I was going to replace the HPOP. Saved me a lotta green!
Old Jul 25, 2012 | 09:36 AM
  #60
rvfixn's Avatar
rvfixn
Hi -
Thanks - bret
Here is the scan with the E450 running, but I don't see 221616, etc...
Command: 2401 response:7F2401FFFF11
Command: 2402 response:7F2402FFFF11
Command: 2403 response:7F2403FFFF11
Command: 2404 response:7F2404FFFF11
Command: 2405 response:7F2405FFFF11
Command: 2406 response:7F2406FFFF11
Command: 2407 response:7F2407FFFF11
Command: 2408 response:7F2408FFFF11
Command: 2409 response:7F2409FFFF11
Command: 240a response:7F240AFFFF11
Command: 240b response:7F240BFFFF11
Command: 240c response:7F240CFFFF11
Command: 240d response:7F240DFFFF11
Command: 240e response:7F240EFFFF11
Command: 240f response:7F240FFFFF11
Command: 2410 response:7F2410FFFF11
Command: 2411 response:7F2411FFFF11
Command: 2412 response:7F2412FFFF11
Command: 2413 response:7F2413FFFF11
Command: 2414 response:7F2414FFFF11
Command: 2415 response:7F2415FFFF11
Command: 2416 response:7F2416FFFF11
Command: 2417 response:7F2417FFFF11
Command: 2418 response:7F2418FFFF11
Command: 2419 response:7F2419FFFF11
Command: 241a response:7F241AFFFF11
Command: 241b response:7F241BFFFF11
Command: 241c response:7F241CFFFF11
Command: 241d response:7F241DFFFF11
Command: 241e response:7F241EFFFF11
Command: 241f response:7F241FFFFF11
Command: 2100 response:7F2100000011
Command: 2101 response:7F2101000011
Command: 2102 response:7F2102000011
Command: 2103 response:7F2103000011
Command: 2104 response:7F2104000011
Command: 2105 response:7F2105000011
Command: 2106 response:7F2106000011
Command: 2107 response:7F2107000011
Command: 2108 response:7F2108000011
Command: 2109 response:7F2109000011
Command: 210a response:7F210A000011
Command: 210b response:7F210B000011
Command: 210c response:7F210C000011
Command: 210d response:7F210D000011
Command: 210e response:7F210E000011
Command: 210f response:7F210F000011
Command: 2110 response:7F2110000011
Command: 2111 response:7F2111000011
Command: 2112 response:7F2112000011
Command: 2113 response:7F2113000011
Command: 2114 response:7F2114000011
Command: 2115 response:7F2115000011
Command: 2116 response:7F2116000011
Command: 2117 response:7F2117000011
Command: 2118 response:7F2118000011
Command: 2119 response:7F2119000011
Command: 211a response:7F211A000011
Command: 211b response:7F211B000011
Command: 211c response:7F211C000011
Command: 211d response:7F211D000011
Command: 211e response:7F211E000011
Command: 211f response:7F211F000011
Command: 2120 response:7F2120000011
Command: 2121 response:7F2121000011
Command: 2122 response:7F2122000011
Command: 2123 response:7F2123000011
Command: 2124 response:?
Command: 2125 response:7F2125000011
Command: 2126 response:7F2126000011
Command: 2127 response:7F2127000011
Command: 2128 response:7F2128000011
Command: 2129 response:7F2129000011
Command: 212a response:7F212A000011
Command: 212b response:7F212B000011
Command: 212c response:7F212C000011
Command: 212d response:7F212D000011
Command: 212e response:7F212E000011
Command: 212f response:7F212F000011
Command: 2130 response:7F2130000011
Command: 2131 response:7F2131000011
Command: 2132 response:7F2132000011
Command: 2133 response:7F2133000011
Command: 2134 response:7F2134000011
Command: 2135 response:7F2135000011
Command: 2136 response:7F2136000011
Command: 2137 response:7F2137000011
Command: 2138 response:7F2138000011
Command: 2139 response:7F2139000011
Command: 213a response:7F213A000011
Command: 213b response:7F213B000011
Command: 213c response:7F213C000011
Command: 213d response:7F213D000011
Command: 213e response:7F213E000011
Command: 213f response:7F213F000011
Command: 2140 response:7F2140000011
Command: 2141 response:7F2141000011
Command: 2142 response:7F2142000011
Command: 2143 response:7F2143000011
Command: 2144 response:7F2144000011
Command: 2145 response:7F2145000011
Command: 2146 response:7F2146000011
Command: 2147 response:7F2147000011
Command: 2148 response:7F2148000011
Command: 2149 response:7F2149000011
Command: 214a response:7F214A000011
Command: 214b response:7F214B000011
Command: 214c response:7F214C000011
Command: 214d response:7F214D000011
Command: 214e response:7F214E000011
Command: 214f response:7F214F000011
Command: 2150 response:7F2150000011
Command: 2151 response:7F2151000011
Command: 2152 response:7F2152000011
Command: 2153 response:7F2153000011
Command: 2154 response:7F2154000011
Command: 2155 response:7F2155000011
Command: 2156 response:7F2156000011
Command: 2157 response:7F2157000011
Command: 2158 response:7F2158000011
Command: 2159 response:7F2159000011
Command: 215a response:7F215A000011
Command: 215b response:7F215B000011
Command: 215c response:7F215C000011
Command: 215d response:7F215D000011
Command: 215e response:7F215E000011
Command: 215f response:7F215F000011
Command: 2160 response:7F2160000011
Command: 2161 response:7F2161000011
Command: 2162 response:7F2162000011
Command: 2163 response:7F2163000011
Command: 2164 response:7F2164000011
Command: 2165 response:7F2165000011
Command: 2166 response:7F2166000011
Command: 2167 response:7F2167000011
Command: 2168 response:7F2168000011
Command: 2169 response:7F2169000011
Command: 216a response:7F216A000011
Command: 216b response:7F216B000011
Command: 216c response:7F216C000011
Command: 216d response:7F216D000011
Command: 220100 response:62010000
Command: 220101 response:6201010014
Command: 220200 response:62020000
Command: 221100 response:62110009FF00FF
Command: 221101 response:62110100
Command: 221104 response:62110400
Command: 221151 response:6211510080
Command: 221600 response:62160001
Command: 221601 response:62160100
Command: 221604 response:62160400
Command: 221610 response:6216100000
Command: 221619 response:62161900
Command: 221624 response:6216240050
Command: 221631 response:62163105
Command: 221679 response:62167900E5
Command: 2216a9 response:6216A900
Command: 22e100 response:62E1000414
Scanning finished
