Front door speakers
Old Mar 10, 2012 | 01:37 PM
  #136
RedBoat's Avatar
RedBoat
Rather Be Floatin
Originally Posted by Mcmurphrjk
On the rears, the high pass filters are mounted on a board on the rear speakers, and a separate connector goes from that board to the factory tweeters.
I removed the filters and wiring, and spliced that wiring into the speaker adapters I used to connect to the Ford connectors.
It will make sense when you see it. I just taped the filters to the speaker wires, after soldering the splice.
That is the way I connected the rears on mine also!
Old May 11, 2012 | 08:18 AM
  #137
Baja Daze's Avatar
Baja Daze
Hey guys!
A few quick questions, if y'all don't mind...
I have a 2012 F-250 XLT Crew Cab with the standard AM/FM/Single CD Sync system (no nav), non-premium sound system.
Before I go tearing into the door panels, can someone tell me exactly what size speakers are in the truck as stock.
The reason I ask is because on various sites (crutchfield, bestbuy) they all list different opinions about what fits my truck.
Crutchfield suggests either 5"x7"/6"x8" or 5-1/4" round for the front doors, and 5-1/4" for the rears. Will 5"x7"/6"x8" fit the rears also???
On the other hand, Bestbuy suggests that 6"X9" will fit all the way around, front and rear. Do they???
What's the real story? What should I be looking for.
Thanks in advance!!!
Old May 11, 2012 | 09:34 AM
  #138
gsxr1300's Avatar
gsxr1300
Pretty sure its 5x7
Old May 11, 2012 | 09:35 AM
  #139
gsxr1300's Avatar
gsxr1300
All four doors
Old May 11, 2012 | 01:04 PM
  #140
Baja Daze's Avatar
Baja Daze
Many thanks.
So, 6"X9" will NOT fit, right?
Old May 11, 2012 | 01:46 PM
  #141
Brandon Bloomquist's Avatar
Brandon Bloomquist
Originally Posted by Baja Daze
Many thanks.
Yeah, not happening without some sheet metal work. That said, It would be easy sheet to make it work with some power tools.
Old May 11, 2012 | 01:52 PM
  #142
Baja Daze's Avatar
Baja Daze
LOL...a sawzall will make anything fit.
(but it sounds messy)
Thanks guys. Off to buy some Infinity 5x7/6x8's...
Old May 11, 2012 | 03:21 PM
  #143
ruschejj's Avatar
ruschejj
No 6x9, but 6x8 or 5x8 have the same bolt pattern. All four cab speakers are the same size.
If you have the tweeters in the doors, they are just under an inch, 7/8 I think. I replaced with 1" tweeters and all I had to do was some trimming with my pocket knife. No worries. The mount hardware that was included with my Polk speakers is perfect and everything appears to be factory.
Old Jul 14, 2012 | 12:08 PM
  #144
MikeInMemphis's Avatar
MikeInMemphis
Crutchfield tells me that the Infinity 682.9CF speakers will fit in the front but not the rear - says that the magnet is too large...
Can anybody confirm that they've installed these behind the rear seat in a 2012 F250 Crew?
Old Jul 14, 2012 | 12:13 PM
  #145
MikeInMemphis
And BTW, this forum is awesome! Thanks for all the great info!!!
Old Jul 15, 2012 | 11:51 AM
  #146
PITS's Avatar
PITS
Mike,
They fit just fine in the 2011. Not sure on the 2012.
I left the tweeters in and everything works/sounds fantastic.
Old Jul 16, 2012 | 10:51 AM
  #147
Brandon Bloomquist
They fit just fine in mine. I didn't have to take the seat out to wrangle the trim panels around, though it would have helped.
Old Jul 16, 2012 | 10:32 PM
  #148
MikeInMemphis
I ordered up two pair of Infinity 682.9cf's from Amazon for $136 delivered. I wanted to order from Crutchfield but they were more than twice that price - $160 per pair!
They're scheduled to be delivered tomorrow - hopefully I'll have a good report tomorrow evening.
Thanks again for all the info.
Old Jul 16, 2012 | 11:24 PM
  #149
mikespecht's Avatar
mikespecht
I purchased the infinity reference 6832 off of ebay for i think it was 50 bucks new for two. they messed up and sent me 4, put them all in the truck. sounds better than stock.
Old Jul 17, 2012 | 05:25 AM
  #150
2000silverbullet's Avatar
2000silverbullet
That's a smokin' deal!
I just ordered 2 sets of JL C5-570's. They're supposed to be here tomorrow. I'm also running new speaker wire, which should be interesting since there's no pass-thru in the doors, it's a male/female clip connection... Thanks Ford, another easy task that's no longer easy.
