New here with a question
Old May 4, 2011 | 07:00 PM
mustang9701's Avatar
mustang9701
2007 6.0
past few months has been running rough till up to 180 degrees. Its been winter so i wasnt too concerned. Now its may, its still runs rough and sputters till warmed up. changed fuel filters recently they were dirty, still no change in running. Yesterday going into town its pouring white smoke. just periodacly (sp) not constant.
Any ideas? head gasket, injector? egr cooler?
Thank you
Bill
Old May 4, 2011 | 07:07 PM
BLADE35's Avatar
BLADE35
Welcome to FTE
check the FICM voltage look in tech folder
have it scanned for codes
If you dont pickup nothing there park it nose down on hill pull the EGR valve out the chamber should be dry if not egr cooler leaking
are you losing any coolant
Old May 4, 2011 | 07:13 PM
mustang9701
yes noticed coolant low when did fuel filters on fri. low again today
Old May 4, 2011 | 07:23 PM
BLADE35's Avatar
BLADE35
odds are the EGR cooler bit the dust
park nose down overnight and check egr valve chamber
If it is the egr cooler you will want to change the oil cooler as well
as the oil cooler plugs and takes out the EGR cooler
Old May 4, 2011 | 08:08 PM
mustang9701
do i replace the egr cooler or eliminate it? should i see water or not see water if its bad?
Old May 4, 2011 | 08:28 PM
BLADE35's Avatar
BLADE35
When you pull the egr valve out look in the chamber it came out of
it should be dry with no signs of coolant in there
I cant tell you weather or not to deleate it depends on the emission requirments in your area and what you want there are alot of options out there
you can get a BPD egr cooler which is supposed to be less troublesome
or BPD EGR deleate its a welded cooler that looks stock
check out the market on egr options good before you decide what to do
Old May 4, 2011 | 10:56 PM
brickie's Avatar
brickie
Replace the cooler and install a coolant filter.Be sure the oil cooler is replaced with the EGR cooler.Deleting the EGR on a late 6.0 can cause more issues than it solves without proper tuning.
Old May 5, 2011 | 03:09 PM
mustang9701
ok i tried removing the egr valve or so i thought, Is it held in with 2 torx head screws? If so i could not get it out but as i pry on it slightly water ran out. So im guessin my egr cooler is shot? Is this job something one can do at home or is there something extremly impossble to get done? i work on locmotives and my dad diesel big trucks for past 50 yeasr so we have plenty of space and tools.
Once replaced, what happens to all that water in the egr valve area?
Old May 5, 2011 | 04:54 PM
bismic's Avatar
bismic
Replace the oil cooler AND the EGR cooler. You should not have a problem w/ the work.
Once replaced, you should remove the glow plugs and rotate the engine by hand to get any water out of the cylinders.
lowridaz22
Sep 30, 2021 08:22 PM
mwkobe
Aug 31, 2011 08:15 PM
billfish1
Sep 30, 2010 09:59 PM
cabledog77
3.8 & 4.2L V6
Apr 14, 2010 02:04 PM
phish555
Nov 16, 2008 06:18 PM
