Shift Solenoid
Old Mar 20, 2003 | 02:52 PM
walt227's Avatar
walt227
Shift Solenoid
I have a 00' Ranger 2wd 3.0. Tranny is missing shifts from 1st to 2nd. It will shift if I let off the gas for a few seconds. Will not shift back down inot first without disengaging the tranny. Dealership says valve body is shot, and entire tranny needs to be replaced! Had a friend of a friend scan the tranny and he thinks it's a shift solenoid. Any thoughts on this/ Any input would be helpful.
Old Mar 20, 2003 | 04:50 PM
Ken00's Avatar
Ken00
Shift Solenoid
Welcome to FTE!!!
I'm not really into trannies but I'm sure you will get some good answers and you could also try asking on our tranny fourm.
Old Mar 28, 2003 | 05:53 PM
jdpullen's Avatar
jdpullen
Shift Solenoid
Ken,
I have the exact same problem with '00 Ranger, 4R44E transmission. No second gear shift. Transmission shifts 1-1-3-4. I've been to three transmission shops. All say the tranny needs to be replaced. What a bunch of bull! I had one shop run the computer diagnostics. From this analysis, I was able to figure out that the shift solenoid (SSB) is the problem! I got trouble codes P0755 (SS2 solenoid circuit failure) and code P1756 (SS2 solenoid failure). The cause of the failure is either: 1. wiring or connector problems in the solenoid electrical circuit, 2. defective shift solenoid B, or 3. defective powertrain control module (PCM). I would also try resetting the PCM.
Jesse
Old Apr 7, 2003 | 01:10 PM
walt227's Avatar
walt227
Shift Solenoid
Well, I replaced the shift solenoid giving the trouble code, but I still have the same problem. Tranny sticks in 1st too long. When I get on the throttle fairly heavy it winds up to the rev limiter and won't shift until I let off. When I dropped the tranny pan there weren't any chunks of metal, which would lead me to believe that the problem still is electrical. I'm thinking maybe PCM or wiring to PCM? Any thoughts on this would be greatly appreciated since the dealer wants a mere $2500 to "fix" my truck.
Walt
Old May 2, 2007 | 01:46 PM
russel's Avatar
russel
i have the same problem the truck hessitates going into 2nd the tranny shop said its skipping second and going right to third they want 2000 to rebuild now im no dummy but the truck did this once a month ago only 1 time then it stopped so i really think its an electrical problem not a rebuild we need help people im sick of being raped by these guys oh and also you can manually dropp down to 2nd and it shifts fine manually HELPPPPP
Old May 2, 2007 | 03:53 PM
Rockledge's Avatar
Rockledge
Check out his Technical Service Bulletin (TSB): https://www.ford-trucks.com/forums/s...2&postcount=19
And then read through this thread: https://www.ford-trucks.com/forums/5...lick-here.html
Old May 2, 2007 | 03:56 PM
fordboy_52's Avatar
fordboy_52
yep, there is a guide that i wrote to fix this problem
Matt
Old May 2, 2007 | 04:12 PM
russel's Avatar
russel
i have a 99 expadition is this the same its a e-40d tranny ?
Old May 2, 2007 | 08:59 PM
fordboy_52's Avatar
fordboy_52
no, its a relative. your 99 prolly has the 5r55e
Matt
Old May 4, 2007 | 01:03 PM
russel's Avatar
russel
Some one on the tranny page said it was a 4r100 and a few others agreed with me its the more expensive type it just has overdrive its a E-40D 3 shops told me
Old May 4, 2007 | 02:19 PM
fordboy_52's Avatar
fordboy_52
i dont think they are right. as far as i have been told the 97-2001 explorers / rangers had the 4r44e and 5r55e trannies
Matt
Old May 4, 2007 | 04:09 PM
russel's Avatar
russel
from 6/99 and up its a 4r100 and before its a e-40d from the ford dealer he looked up my vin and he said to change the solinoid coil pack so im gonna try ford dealer
Old May 9, 2007 | 03:37 PM
russel's Avatar
russel
expedition trans shift problems
i have a 4r100 trans i just wanted to thank people for the help and spread the news i have a 1999 expedition and the tranny was skipping 2nd gear and hessitating i asked several people and mechanics the mecs said tranny needs to be rebuilt 2400 $$$$$$ NOTTTTTTTTTT i got the solinoid pack and it took 2 hrs to change never did one so very easy but messy .unplugging the plug was the hardest part the solinoid cost 130 rebuilt and 175 new a no brainer GET THE NEW ONE THANKS FOR THE INFO if any one has any questions i will be checking this site VERY HELPFUL
brolandscape
Oct 30, 2015 02:30 PM
sudsmcduff
Oct 19, 2014 02:30 PM
02f550
May 15, 2014 08:47 PM
Mowing Man
Apr 5, 2014 05:59 AM
Casepuller
Dec 31, 2013 02:40 PM
