Australia Chapter Join Chapter , Leader: OPEN
Firestone R4-Tech
Old Jul 7, 2011 | 03:41 AM
  #106
ChunderDownUnder's Avatar
ChunderDownUnder
Originally Posted by IB Adrian
The buckets mentioned my Nkelly - you can get different spec buckets (that affect the castor) from your dealership, otherwise I think Pedders makes them adjustable.
Are you inquiring because your rig has the infamous "pulls left" syndrome?
Funny u mentioned that Adrian. My has started to drift left over the last two months. Checked tyre pressure all good there. I swap front to back every 5000 kms.
Old Jul 7, 2011 | 04:58 AM
  #107
SSSimon's Avatar
SSSimon
I mention the castor adjustment cause of the overly vague straight ahead steering of my truck. A steering damper improved this by a huge amount, however I know this is only treating a symptom - and the steering damper is likely to go (or get taken off) when 4WDing.
So an adjustable castor kit would be a good thing to have to get the beasty to track a bit better in a straight line.
Bryan, I reckon those airbagit one gallon split tanks, i.e. one per axle, would be OK. All you need to do is put a T piece in the air line going to each air bag and then plumb 1/2 the tank in per side.
Do you know what volume your air bags are?
Old Jul 7, 2011 | 05:24 AM
  #108
Nkelly's Avatar
Nkelly
Farkall User
Got no idea.
Old Jul 7, 2011 | 10:42 AM
  #109
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I think with your model vehicle (an 03), you still have the US spec castor fitted.
There was a TSB that I released that should resolve it - sometimes dealerships will do the work outside of warranty period, mention the issue to them, and that there is a TSB for it and they might change them free of charge.
The reason it will have gotten worse is that the steering links on your truck are probably on their slow way out - which isn't all that uncommon on the RHD trucks, although new ones still have a fair bit of play in them (check the play in yours). If you know a decent shop that can rebuild the ends, that would be your cheapest and best bet.
I would also check the steering links like I mentioned to Brian. 8 times out of 10 it will be the cause.
The other 2 times it will be Ball Joints. How many kilometers on your truck?
Old Jul 8, 2011 | 06:36 AM
  #110
SSSimon's Avatar
SSSimon
Regarding getting the steering linkages checked, would you risk taking your truck to a local steering specialist and get them to check it out?
I'm always worried that these trucks are a little unusual and most places wouldn't have seen too many - in which case you may not get a good job done.
So far I've seen about 20 F250s and 2 F350s in the ACT.
Old Jul 8, 2011 | 07:24 PM
  #111
Nkelly's Avatar
Nkelly
Farkall User
20 F250's fark me ive seen about 7 different ones down here...
With our Ftrucks we have to find front end alignment shops with pits,the 4 poster set ups are no good,our trucks wont fit on..
A bob jane tyre joint at ringwood has a pit,but i think they dont know what they are doing cuz when they had my truck,it only took them about 20 mins and i had it back,wasnt happy with the way it was steering so i found another guy who does Ftrucks all the time on his pit,he was the guy who told me about the buckets ontop of our kingpins,after talking to tim @ rocket sports trucks,he has had his own buckets made up,so im going to get him to fit them,then get matt the front end guy to redo my front to 8 degrees caster as tim recomends and see how she steers..
Oh and after i put the longer draglink adjuster on,my front end is back to normal as far as the steering goes,pitman arm is fine..
I only have to get a adjustable panhard bar cuz my front end seems about inch to the passenger side.
Old Jul 9, 2011 | 07:18 PM
  #112
ChunderDownUnder
Come on Bryan. Grab the video camera thats mounted on ya bedroom ceiling and get us some footage of your suspension. Failing that, jump in ya truck and drive the 1000kms up here and give us a look. Its killing me man.
Old Jul 10, 2011 | 06:11 AM
  #113
Nkelly's Avatar
Nkelly
Farkall User
Went too take ya video,but the farker aint working,unfarkenbeleivable
New camera coming up....
Old Jul 10, 2011 | 11:18 PM
  #114
BigF350's Avatar
BigF350
FTE Emeritus
Any full size truck alignment place will be fine - just ensure they know that there will be a little bit of play in there (I have seen ones that have come new off the part shelves that have been "out of spec" according to the book)
Old Jul 24, 2011 | 07:16 AM
  #115
Nkelly's Avatar
Nkelly
Farkall User
Here's your video you requested bruvva..
‪F250 wih airbag suspension‬‏ - YouTube
Old Jul 24, 2011 | 04:19 PM
  #116
ChunderDownUnder
Thanks m8. You are right , that is a nice lift. Can you get one with bags in operation. You can get another 4" out of it at full pressure right. Oh one thing I didnt see in that scenic shot bro. "The for Sale sign" lol.
Went to rep ya but the rep police got me
Old Jul 24, 2011 | 05:38 PM
  #117
Nkelly's Avatar
Nkelly
Farkall User
Atm all ive got is 4 switches too operate the airbags,so ive ordered this accumaltor tank X2 airtank air tanks and this digital controller Upgrade To Smartride 5-Presets Pressure Controller installed on your Plug and Play. Other options available as shown. Ask your salesperson ive got the one in the picture too the right,with the height controllers,it has 5 height settings,they let me have it for $450,so when i get it set up which should'nt be long i'll do another vid..
Old Jul 25, 2011 | 03:58 PM
  #118
BigF350's Avatar
BigF350
FTE Emeritus
ha - appreciate the tour of the chook shed too
Brian - I sorted out the reps for ya
Old Jul 26, 2011 | 05:40 AM
  #119
ChunderDownUnder
thanks Adrian. Did I end up sending them to you ??
Old Jul 26, 2011 | 06:22 AM
  #120
BigF350's Avatar
BigF350
FTE Emeritus
You did
