Australia Chapter Join Chapter , Leader: OPEN
Firestone R4-Tech
Old Jun 19, 2011 | 04:09 AM
  #76
ChunderDownUnder's Avatar
ChunderDownUnder
So thus far I can tell em to jam the air hose and the compressor (I got the ARB). less box's = less freight.
Old Jun 19, 2011 | 07:14 AM
  #77
Nkelly's Avatar
Nkelly
Farkall User
Nah get their compressor (its the 7600 on their website 3/4hp 4cfm),it blows ARB's out the window,it all set up with the air engine,the whole setup is $699 compared to ARB HALF size compressor for $ 350 the 7600 is the same price and twice the size .
Its just their hoses and fittings that suck goats u know what.
That black hose you can see is that fekkin stiff it hardly bends,the 1/2" hydraulic hose and straight through fittings will work a charm and be bullet proof,cuz thats what we need bruvva,no crap blowing off whilst we way up woop woop .
Old Jun 19, 2011 | 08:38 AM
  #78
SSSimon's Avatar
SSSimon
Good work Bryan. Yes, more pics as you go. Can't wait for Lyn's report on the plushness of the ride when you do the road test!
Maybe the ride will be so good you'll be able to use your truck for bulk egg deliveries
Old Jun 19, 2011 | 02:15 PM
  #79
Nkelly's Avatar
Nkelly
Farkall User
I put 120lbs in the front airbags and give the front a bounce with out shocky's on and its got still plenty bounce at that pressure.
Old Jun 20, 2011 | 12:49 PM
  #80
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Looking good
The steel gauge they use for the air-bag brackets off the chassis is particularly nice!
Are you going to set it up for air-tools too? My last tree-fiddy had that, was great when you had a flat and could rattle gun the wheel on/off in a minute.
Could the compressor fit underneath the back seat?
Old Jun 20, 2011 | 02:25 PM
  #81
Nkelly's Avatar
Nkelly
Farkall User
Originally Posted by IB Adrian
Looking good
I have a airline coming out either side at the rear of the steps.
Not enough room plus the mrs would whine about the noise,not wrth the headache.
Old Jun 20, 2011 | 11:03 PM
  #82
ChunderDownUnder
how much lift u reckon with 120lbs of air. I already have the ARB compressor installed in the back. You reckon its got enuf oommff to handle the bags.
I also like the look of this
http://www.riffraffdiesel.com/mm5/me...731-SUS-OUO-TB
Old Jun 21, 2011 | 06:18 AM
  #83
Nkelly's Avatar
Nkelly
Farkall User
Riffraff Diesel: One Up Offroad Traction Block & Traction Bar
120lbs max's the bags out full lift,the ARB will be fine,it might struggle if you were **** farting around lifting the bags up and down,up and down,but we wont be doing that, so all ya need is the air engine and the control switches/air pressure guages.
1/2" 3-Position 300psi , 15mm (5/8") Orifice 160watt coil, 300psi 8-Cyl Air-Engine Manifold Valve - With all options: Bag Checkvalve, Speed up/down controller, Compression Fittings, Wire Harness, Muffler, Dual Gauges.
That traction bar/lift block is top idead.
Old Jun 25, 2011 | 05:21 PM
  #84
Nkelly's Avatar
Nkelly
Farkall User
Started on the **** end
Ok all that is out
Took the top off the rivets with the grinder,but do you reckon the front spring hanger would come off,no fekkin way,so i got the ol trusty gas axe out,that moved it,also i had to blow the bracket off that holds the handbrake cable's,im going to have to weld that back on somewhere,most likely on the side of this control bracket..
Slowly coming together..
When i put on all the airlines on for the front bags,i could'nt get the connections from leaking,so i sent airbagit a email saying their fittings suck,so i went down and my enzed hydraulic hose man,showed him my fittings told him they were leaking and i wanted hydraulic hose/fittings made up,and he said you dont need that you just need these
they go in side the airline then you put the fitting on and then the olive/ferrell,so i sent airbagit another email saying that their product is good but the people who pack the kit are a bunch of morons and could you please go and tell them to get their **** together,so they have asured me that it wont happen again..
also had to wait for 4 of these
Sick of doing this waiting for the parts i need,should of been back on the road a week ago ...
Old Jun 25, 2011 | 09:39 PM
  #85
ChunderDownUnder
Are the pleasures of dealing with somebody 7000kms away. Thats the exact same scenario I try to stress to Clay. Have to think of every contingency regarding any install. Cause if some thing aint right we cant run up to Wallmart and get it sorted. Any way m8 thanks for the pics, if anything you may be helping out another bruva who may consider doing this. (like me). May the god of easy wrenching be shining on you.
Old Jun 26, 2011 | 06:00 AM
  #86
Nkelly's Avatar
Nkelly
Farkall User
Well i had to take the rear front bracket off after i worked out the best place for the handbrake cable bracket and welded it on,did i tell ya i LOVE my mig welder..
Old Jul 1, 2011 | 02:56 AM
  #87
ChunderDownUnder
how ya going with Bryan. Any more pics.?? You dealt with the pitman arm yet???
Old Jul 1, 2011 | 04:34 AM
  #88
Nkelly's Avatar
Nkelly
Farkall User
Rear of the rear axle passenger side
Drivers side rear axle
The passenger side control arm bracket was a pain,had move the fuel tank away from the chassis so i could tighten the bolts up,even to put the nuts on the bolts was annoying,fuel lines and electric wires in the way all fastened to the chassis.
Almost done
Old Jul 2, 2011 | 09:42 PM
  #89
ChunderDownUnder
Did you get a good pic of that axle code sticker before you covered it up. Never know you might need that info at a later date.
Old Jul 2, 2011 | 10:35 PM
  #90
Nkelly's Avatar
Nkelly
Farkall User
HMMM no i didnt..
I had to go get shorter bolts for the brackets that go around the rear axle,idiots set 9" bolts instead of 8" bolts,and also diff housing bolts,the ones they sent were too short,but thats not their fault,i have an after market diff housing..
Last BIG job was the rear panhard bar
Also had to drill holes for the brake line bracket,not a biggie but still had to be done..
Just gotta chuck the wheels and shocks back on,hopefully the procomp's i have will do the job till my new procomps get here.
