i have a 351m in my 1989 f350. ever since i got it which is about 6months ago. wen i take her out she runs hot. i start her up go play around in the mudd and cruise and stuff and then about 10 - 15 mins later shes hot. i changed the thermostat to a 180 degree but still ran hot. i believe the water pump work because i have watched the water in the radiator being pumped. i rly want to get this fixed so i can ran her more than just 10 mintues if anyone can help i would greatly apperciate it!
What Eddiec1564 said,if it's plugged a Radiator shop can rod it out for you to improve the flow. also you can normally hear a fan running when the fan clutch is engaged mine sounds like an airplane taking off,hard to miss.
no smoke. it does bubble when it get hot. fan shroud does look a lil little but how do i tell? how do i tell if the fan clutch is bad? and yes it is a 351m it does have a engine swap
Regarding fan clutch operation a symptom I get when it's not working is overheating especially when towing,and as stated above the fan can be heard when it is engaged it moves a lot of air.in my experiance they don't seem to last long either.
