cooling system nightmare!!!!!! help please!!!!
Old Apr 1, 2011 | 02:24 PM
palmettotiger1's Avatar
palmettotiger1
Unhappy cooling system nightmare!!!!!! help please!!!!
i have a 351m in my 1989 f350. ever since i got it which is about 6months ago. wen i take her out she runs hot. i start her up go play around in the mudd and cruise and stuff and then about 10 - 15 mins later shes hot. i changed the thermostat to a 180 degree but still ran hot. i believe the water pump work because i have watched the water in the radiator being pumped. i rly want to get this fixed so i can ran her more than just 10 mintues if anyone can help i would greatly apperciate it! old thermostat had the guts taken out of it
Old Apr 1, 2011 | 02:36 PM
Kemicalburns's Avatar
Kemicalburns
in 89 the motor should be a 351w unless it was swapped out. is the motor that is in there EFI?
flush the radiator, make sure there is a fan shroud and perhaps replace the fan clutch.
Old Apr 1, 2011 | 06:57 PM
jimbbski's Avatar
jimbbski
Not sure on this but can you put a reverse rotation water pump on a normal rotation front cover and visa versa? Just throwing this out there. I'm not sure on this at all.
Old Apr 2, 2011 | 02:38 AM
xlt4wd90's Avatar
xlt4wd90
Yes, I believe it's possible. I once went to buy a new water pump, and the first one that the parts guy brought out looked exactly like mine, except the blades on the impeller were pointed in the wrong direction. Then he brought out the exact replacement, with the blades pointed in the same direction.
Old Apr 2, 2011 | 07:02 AM
palmettotiger1
it did have a engine swap. its carburated. has a fan shroud but it look small lik it a replace ment. how do u tell if the clutch is bad?
Old Apr 2, 2011 | 11:11 AM
Kemicalburns
pull some plugs and see how they look. are you having to add radiator fluid at all?
Old Apr 2, 2011 | 01:06 PM
xlt4wd90's Avatar
xlt4wd90
The fan clutch usually fails when its viscous fluid leaks. You have to take the fan off of the clutch to see if there are any oily dirt collected between the fan and clutch. If you see that, the clutch needs to be replaced.
Old Apr 2, 2011 | 02:16 PM
Lance Hogan's Avatar
Lance Hogan
My experiences with running hot were related to ignitition timing being off and running lean. I would check to make sure your timing is set correctly (the marker could be off; mine was) and read your plugs to see if you are lean.
Just my 2 cents.
Lance
Old Apr 2, 2011 | 03:34 PM
palmettotiger1
thnx alot guys u have given me tons of idea to check ill let u knw how it goes!
Old Apr 2, 2011 | 08:50 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Did you put the new thermostat in the right way? Bridge towards the water neck.
Old Apr 2, 2011 | 09:38 PM
palmettotiger1
im not sure i didnt put it in my uncle did. im in iraw right now lol ill ask
csherrill
Jan 28, 2016 04:07 PM
KLWillis
1983 - 2012 Ranger & B-Series
Mar 28, 2011 02:06 PM
cbrnflt
Sep 13, 2010 03:20 PM
koalamazed
Aerostar
Mar 12, 2006 09:57 PM
ag-ford-4x4
Jan 17, 2006 10:24 AM
